Latest post Fri, Jul 24 2020 1:54 PM by jcmcnamee. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Jun 5 2020 7:37 PM
    numbers on the source/record window - what are they?
    Haven't seen these before 2019.12.1, and the ones in the center block the frame counter in trim mode.
    2017 MacBook Pro Aja IO/XT Mojave 10.14.6 MC 2019.12.1 [view my complete system specs]
  • Fri, Jun 5 2020 7:55 PM In reply to
    Re: numbers on the source/record window - what are they?
    Sorry- a restart got rid of it. Thought I'd seen it yesterday so will keep an eye out.
  • Fri, Jun 5 2020 9:45 PM In reply to
    Actually, after the restart it came right back when trimming- leaving a remnant of the trim counter that gets compounded, numbers overlaying on numbers.  Anyone else?
  • Sat, Jun 6 2020 4:46 PM In reply to
    • Verne Mattson
    • Joined on Sat, Nov 19 2011
    • Northern New Jersey
    • Posts 23
    • Points 285
    I'm seeing the same thing in Symphony. I'm on 2019.12.1, High Sierra 10.13.6. It's very annoying and it gets in the way of seeing the parameter numbers. I'm also seeing in trim mode.
    2009 MacPro, OS 10.11.6, firmware upgraded to 5,1, CPUs upgraded to 12 core 3.33GHz. 32 GB RAM. [view my complete system specs]
  • Tue, Jul 21 2020 9:21 AM In reply to
    • SaraPJ
    • Joined on Wed, Sep 21 2011
    • Posts 4
    • Points 60
    I'm also getting these numbers appearing after I use the trim tool. They stay on there even if you switch to other workspaces and switch back to the edit workspace. Did you find a solution to this? Thanks!
  • Tue, Jul 21 2020 2:58 PM In reply to
    • jcmcnamee
    • Brooklyn, NY
    • Posts 287
    • Points 3,050
    I had this problem and I think I got rid of it by deleting the settings.xml file in my project. This was a project that had previously been used in MC 2018 and 2019. I may have also made a new project of the same format and dragged all the old bins into it. Can't remember which worked but I'd at least start by deleting that settings.xml for the project.
    Media Composer 2020.8 / OS 10.15.6 27" iMac 5K 2017 [4.2 GHz Intel Core i7, 64 GB ram, Radeon Pro 580 8 GB] [view my complete system specs]
  • Tue, Jul 21 2020 5:01 PM In reply to
    Thanks for the suggestion, but it didn't work for me.  Deleted Settings.xml.  Created new Project.  Created new user. Same thing.
  • Fri, Jul 24 2020 12:02 PM In reply to
    • SaraPJ
    • Posts 4
    • Points 60
    This didn't work for me either - thanks though. Glad someone managed to fix it, it's pretty annoying!
  • Fri, Jul 24 2020 1:54 PM In reply to
    • jcmcnamee
    • Brooklyn, NY
    • Posts 287
    • Points 3,050
    Shoot, wish I knew what fixed it for me, then. It definitely went away and hasn't come back.
