Latest post Thu, May 21 2020 11:19 PM by brian. 2 replies.
  • Thu, May 21 2020 3:13 PM
    • brian
    • Vancouver BC
    • Posts 65
    • Points 695
    Using Shapes in Symphony Color Corrector
    Having the shapes tool within the color corrector was a great addition to symphony, but I can't seem to make the window large enough to see where to place my points where I want and can only get a rough placement. (other than to float the window and enlarge it across two monitors, which somewhat helps) I tried to add an enlarge button using the command pallete but it won't let me change those buttons already in the CC centre window. Any tricks?
    Avid 2019.9 Intel Xeon CPU E5-2630 v3 @ 2.40GHz 2.40GHz (2 processors) 32.0 GB RAM 64-bit Operating System, x64-based processor Windows 10 Enterprise... [view my complete system specs]
  • Thu, May 21 2020 8:20 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,439
    • Points 17,745
    Re: Using Shapes in Symphony Color Corrector
    Clicking on the image and hitting CTRL-L zooms into the image in every mode I've ever tried.  CTRL-K zooms back out.  ALT-CTRL gives you the hand tool to navigate around.
    Obviously it doen't make the window bigger, but it gives you more precise control of placement.
  • Thu, May 21 2020 11:19 PM In reply to
    • brian
    • Vancouver BC
    • Posts 65
    • Points 695
    Thanks for the tip. That helps!
