Latest post Sun, Mar 29 2020 2:25 PM by Lukas Boeck. 15 replies.
  • Thu, Feb 27 2020 10:15 AM
    Best CPU for Avid MC - i9, Ryzen 3950X or Threadripper?
    Moving over from Macs and looking to build a hefty PC that in amongst other things will need to run Media Composer without issues. I am trying to decide between the Intel i9's and the AMD Ryzen 3950X or 24 core Threadripper. Has anyone got experience running MC on the AMD's CPU's and how do they perform?
    Also looking for a GPU and am think of the GeForce RTX 2080 Ti over the more expensive Quadro RTX500 - will the GeForce be okay with MC?
    Any advice on these specific CPUs bad GPU's will be very much appreciated!
    Thanks.
  • Thu, Feb 27 2020 2:29 PM In reply to
    • Revenger
    • Joined on Wed, May 11 2011
    • Estonia
    • Posts 90
    • Points 1,145
    Re: Best CPU for Avid MC - i9, Ryzen 3950X or Threadripper?
    Also planning to build a new workstation so any real life experiences with AMD and Media Composer are greatly appreciated!
    MC 2019.12; HP Z800; Windows 10 Pro 64-bit; Dual Quad-Core Intel(R) Xeon(R) X5570 @ 2.93GHz; 24GB (6 x 4GB) DDR3 1333 ECC RAM; NVIDIA Quadro FX 4800 (driver... [view my complete system specs]
  • Thu, Feb 27 2020 3:16 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,432
    • Points 61,250
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
  • Thu, Feb 27 2020 3:45 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 591
    • Points 6,995
    Normal 0 21 false false false DE-AT X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:8.0pt; mso-para-margin-left:0cm; line-height:107%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;}
    We don't have much experience with AMD on this forum ATM.
    People trying it and failing. not sure whether CPU or GPU related.
    whether Ryzen or threadripper should depend on the amount of pci-e lanes you need.
    then again, there are no convincing workstation boards that make the threadripper lanes available either.
    I’m still looking at Intel Xeon W-3245 to be honest.
    If I could have boards like I can get for intel for threadripper I’d try it.
    I do think that MC will play nicely with ZEN 2 architecture.
    GPU wise, you'll get much more from the GTX/RTX card.
    The likelyhood for problems increases a bit but none have been insurmountable thus far.
    I have a 1070 and never had any issues.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Thu, Feb 27 2020 3:49 PM In reply to
    Has NO one had any success running a Ryzen 9 3950X CPU with Avid?
  • Thu, Feb 27 2020 3:50 PM In reply to
    • Posts 11,323
    • Points 232,540
    Like Adman said it might be best to stick with Avid qual.
    Aside.....   here is some scoop on Intel vs AMD
    Apple – Intel CPUs only (with AMD graphics)
    Lenovo – only Intel CPUs in workstations, Nvidia only graphics, no AMD graphics options
    HP – only Intel CPUs in workstations, mostly Nvidia graphics, some AMD graphics options
    Dell – only Intel CPUs in workstations, mostly Nvidia graphics, some AMD graphics options
    Avid video always required higher end systems – workstations.  That is what we qualify.  Our partners provide us with systems and those systems do not have AMD CPU options.
    Why don’t we test low end consumer systems with AMD processors (or even Intel processors)?  Historically, consumer systems don’t perform well, have lower quality, lower CPU life expectancy and generally are not meant to run 24/7 doing video editing.
    Hope that helps
  • Thu, Feb 27 2020 3:52 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    Damian_Knight:
    No, but nobody has failed either.
    I'm quite willing to help you in your attempts Stick out tongue
  • Thu, Feb 27 2020 7:27 PM In reply to
    • cls105
    • los angeles
    • Posts 513
    • Points 6,590
    actually a few have failed.  I remember my 1st generation ryzen not working well for media composer.  And i've read about bad performance from other people here.
    Try it out.  But don't be shocked if there is a delay when hitting play or choppy playback.  At least youll have a transcoding beast.
    w10, mc 2020.4, diy x299 7940x [view my complete system specs]
  • Thu, Feb 27 2020 7:34 PM In reply to
    I think I will stick to an Intel i9 as I know Avid is okay with those. Just to be safe!!
  • Fri, Feb 28 2020 11:34 AM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 1,178
    • Points 14,570
    Have always thought that upgrading my graphics cards has had no effect.  I dont think Avid uses its GPU much, whatever the process?  Just went from a K2000 to a K4400 - nothing changed as far as I can tell.Confused
    Symphony 2018.12.10, Blackmagic Intensity Pro 11.1 (unsatisfactory in full res UHD though for client monitor), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K4200, Asus X99-A Mobo, i7 5820K 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 array @ 450Mbs
  • Fri, Feb 28 2020 11:41 AM In reply to
    I am budgeting for a Quadro RTX 5000 but really I would rather buy a GeForce 2080Ti - but I am not too sure how nicely they will play with Avid where as the Quadro is certified but its eye watering expensive next to the GeForce
  • Fri, Feb 28 2020 12:39 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    DIESELE:
    It's really only for plugins. Sapphire, BCC.
    with onboard effects you'll see about 0% improovement.
    The consumer card comes with a 20% chance, that you'll have to driver troubleshoot once in it's lifetime.
    Don't know if that's acceptable in your shop.
  • Fri, Feb 28 2020 10:06 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,419
    • Points 97,410
    Last computer I built started out with a high end gamer's card, and when I could justify it moved to Quadro to become a fully qualified system.  In the PC world you can progressively upgrade almost everything.
  • Sun, Mar 1 2020 11:15 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,368
    • Points 53,960
    For what its worth, I have no trouble with my AMD boxes.
    https://www.amd.com/en/products/frontier
    Most complaints with AMD performance and stability go back to the old VIA chipsets, and when AMD did not support the SSE extensions.
    Still, certified systems instill a certain confidence.
    Using MC 20.6. Avid FX6.4, Vegas Pro 17/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Wed, Mar 25 2020 10:38 AM In reply to
    • B3n3d1kt
    • Joined on Tue, Mar 24 2020
    • Germany
    • Posts 11
    • Points 110
    At work I built a custom workstation with Threadripper 3960X. I will make a separate post about it.
    When I talk about Threadripper, I mean the Zen2-based Threadripper 39X0X. The first two generations had a design problem resulting not to bring the raw performance of the CU to the ground. AMD has changed it for the Zen2-Threadripper.
    There a three big plattforms on the market: consumer, HEDT, server.
    Consumer:
    The fastest CPUs on these plattforms are quite powerful (Ryzen 3950X, i9-9900) and could probably run a workstation. But these consumer plattforms (dual channel RAM, 24 PCIe lanes) are not designed to run a NLE with GPU, M.2 SSDs, I/O, additional 10Gb network adapter. You will face lane sharing and performance issues.
    I thought about building the workstation with Ryzen 3950X, but Threadripper has just been 900 € more.
    HEDT:
    This plattform is related to the server plattform. The CPU and chipsets are quite similar, with some limitations to HEDT.
    HEDT would be Cascade Lake(-X/-W) or Threadripper and server Xeon or EPYC. Overall you can say that you get more performance for the same money on Threadripper/EPYC.
    No Threadripper mainboard offers U.2 (M.2 with cable), which is unpleasent because M.2 SSDs are only available up to 2 TB (some 4TB) and U.2 SSDs offer 8 or 15 TB with the price still "okay" (before Corona). And you "only" get a quad channel interface on Threadripper. But compared with Intel you get the newer plattform (PCIe 4.0, DDR4-3200, more efficient).
    If you want to build a Intel based custom workstation, go for Cascade Lake-X (i9-109aa0X). You get a 18C for 1000€ net. Probably not the fastest, but solid. The price should be between 3950X and 3960X.
    So far I haven't noticed any problem with Avid.
    Just a few issues to get everything running. BIOS update to have all 24 core was the easy part - except I had to disconnect all SATA drives to find a bootable drive after the update. And newly installed Avid, even with new projects/profiles, crashing on dual monitor setup has been tough. Thanks to the communiy I could solve it (Asus audio driver comes with Sonic that caused it --> uninstall --> let Windows update install the driver).
    But here is the big BUT:
    You will have to setup everything and take care about everything by yourself. So you should have some experience with it or get help from someone who has.
    The web and this forum will/can help, but you cannot say: Avid/retailer/Dell/HP, get the *** system working!
    MC 2019.12 (Win 10 1909) custom Workstation: AMD Threadripper 3960X (NH-U14S TR4-SP3 + NF-A15), ASUS TRX40-E Gaming, 64GB DDR4-3200 Corsair, MSI RTX 2070... [view my complete system specs]
