Latest post Fri, Feb 28 2020 11:45 AM by ripvanmarlowe. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Feb 18 2020 8:45 PM
    • Scott_L
    • Joined on Wed, Oct 26 2011
    • Posts 12
    • Points 170
    AS-11 Export UK HD Shim
    Getting this error (console report) when trying to export to AMA AS-11 UK HD Shim
    FD to DFM conversion failed. Error: Required property 'descriptor.samplerate' has wrong format or missing in FD
    I don't see any options in the shim to tell it sample rate.  Is there something else it's referring to?
    16 Audio tracks with silence on traks that don't have actual sound data. 48k 24bit project
    Trks 1&2 = Stereo
    Trks 5-10 = 5.1
    All others = silence
    Media Composer Symphony v2018.7 on PC
    -S
  • Wed, Feb 19 2020 12:15 PM In reply to
    Re: AS-11 Export UK HD Shim
    Is the sequence definitely 50i not p?
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 32GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Wed, Feb 19 2020 5:38 PM In reply to
    • Scott_L
    • Posts 12
    • Points 170
    Yes, thanks for asking.  Definitely 50i
  • Thu, Feb 20 2020 12:18 PM In reply to
    I would render/mixdown/transcode all the media on the timeline and then try to export.
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440/800/820 PC's on W7/10 x64. 3 x Mac, 4 x PT 2019.12 HDX, S6 , X-MON, all on PCs. NEXIS E4 & ISIS 5000 X... [view my complete system specs]
  • Fri, Feb 28 2020 11:30 AM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 1,171
    • Points 14,495
    Is UK HD shim only for 2 stereo tracks?  I always delete all tracks and make sure there are only 2 on a timeline thas being AS11'd - but then i havent done 5.1 yet.
    Symphony 2018.12.10, Blackmagic Intensity Pro 11.1 (unsatisfactory in full res UHD though for client monitor), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K4200, Asus X99-A Mobo, i7 5820K 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 array @ 450Mbs
    • DIESELE
    • Posts 1,171
    • Points 14,495
  • Fri, Feb 28 2020 11:45 AM In reply to
    It's either 4 or 16 tracks. 4 tracks for a non surround program or 16 with surround. 1-4 are stereo mix and M&E, next 12 are the 5.1 full mix and 5.1 M&E.  Like the OP states, any empty tracks need to be filled with silence as PCM audio.  So in his case there's no M&E tracks but those tracks still need to be "full".  These are flagged as R123 4b for a 4 track file or R123 16c for surround.  Looks like his audio layout is fine.
    OP, did you ever get to the bottom of this?
    Andi
