Latest post Fri, Feb 14 2020 11:50 PM by smrpix. 4 replies.
  • Fri, Feb 14 2020 10:35 AM
    • Florian
    • Germany
    • Posts 336
    • Points 4,210
    synchronizing Audio - different sources
    Hi there,
    i am about to edit a docfilm, having 2 cams, plus 6 Tascam DR 10L Audio Recording Devices.
    I just want to make sure: Is syncing by waveform still the Way to Go?
    Since i don't know if there is any realtime tc or clapperboard was being used ...
    i am expecting the worst 🙄 and don' t want to shift around the files by minutes
    thanks in advance
    Florian
    MacBook Pro Retina 15", 2.5Ghz QuadCore i7, OS Catalina 10.15.6, Avid MC 2020.6, 16GB Ram, AMD Radeon R9 M370X iMac 4,2, i7, 16 GB, MC 2020.6, OS... [view my complete system specs]
  • Fri, Feb 14 2020 11:48 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 260
    • Points 2,765
    Re: synchronizing Audio - different sources
    I haven’t tried this yet looks good tho’
    https://vimeo.com/314973861
    I think Jeff here works for avid
  • Fri, Feb 14 2020 11:55 AM In reply to
    • Susi
    • London, UK
    • Posts 583
    • Points 6,700
    Can you not contact anyone involved in the shoot, to ask about their shooting methods?
    (Worth knowing something about length of takes, too!)
    As an old-timer, I'd say all you need to know is
    - that the devices all run-to-time using the same methodology (eg.quartz crystal timer)
    - and that there are recognisable synch points; even if not a clapperboard, a handclap is very useful if you can see it in shot from both cameras, and hear it on all the audio recordings
    Media Composer 2018.9.0 on 13" early-2015 Macbook Pro (OSX10.13.6) 3.1GHz Intel Core i7, 16GB 1867 MHz DDR3 Intel Iris Graphics 6100 1536 MB Gizmos... [view my complete system specs]
  • Fri, Feb 14 2020 4:02 PM In reply to
    • Florian
    • Germany
    • Posts 336
    • Points 4,210
    Thanks to both of you!
    Guess i have to take a roundtrip through Plural eyes via AAF.
    I will See...
  • Fri, Feb 14 2020 11:50 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,443
    • Points 17,810
    Plural Eyes is fine.  But you can also do it right in Avid.
    https://www.youtube.com/watch?v=Qy6JZpaP2T0
