Latest post Mon, Feb 3 2020 7:35 AM by Cutyes. 3 replies.
  • Fri, Jan 31 2020 8:25 PM
    • jdcoletv
    • Joined on Tue, Aug 16 2011
    • Posts 92
    • Points 1,110
    Audiosuite errors
    So , I have been gettign the following errors after working with audisuite and audsuite track effects and then the system crashes: Exception VDM3BobVideoOut:::OPresync. Error in Bob device Start; AMEResourceManager: reconfigHW_LegandBob_play Error.
    Makes it impossible to add effects. Working with a an hour long HD QT file.
     In 2018:12.9: this version full of gotchas!
    MacBook Pro (15-inch, 2017) running with 16gb and Sierra (10.12.6), Radeon Pro 560 4096 MB. [view my complete system specs]
    Regards,
    Jeremy
  • Sat, Feb 1 2020 9:22 AM In reply to
    Re: Audiosuite errors
    Are you using an I/O device?
  • Sat, Feb 1 2020 10:49 AM In reply to
    • jdcoletv
    • Posts 92
    • Points 1,110
    The  devices I am using: an AJA T-tap along with a couple of raid drives, an external thunderbolt raid controller box and card and an owc thunderbolt dock.
    Regards,
    Jeremy
  • Mon, Feb 3 2020 7:35 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    Did you check if it happens in software-only mode?
    Is the AJA software up to date?
    In the AJA control panel (Tabs 'Format' and 'Video Setup') do the settings for 'Progressive' vs. "PsF" vs. 'Interlaced' match your project settings?
