Latest post Mon, Feb 3 2020 9:48 PM by zefrem7. 3 replies.
  • Fri, Jan 31 2020 1:37 AM
    • zefrem7
    • Joined on Thu, Mar 19 2009
    • Posts 46
    • Points 580
    Panning audio effect
    I was wondering if there is a way to create a panning audio effect? For example, making a car sound like it's starting from the left speaker, then finishing its drive-by from the right speaker?
    Thanks!!!
  • Fri, Jan 31 2020 10:08 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    Re: Panning audio effect
    A simple way to do it is to split the clip (Add Edit), pan the segments individually and then use a fade to make the transition.
  • Sat, Feb 1 2020 12:18 PM In reply to
    • jo56lu
    • Luxembourg
    • Posts 46
    • Points 610
    To achieve this follow these steps:
    1. Make shure Audio Keyframes are displayed ( is active) and set to display pan information on the track you want to work on
    2. In the Audio Mixer switch to Automation Mode
    3. Then either insert a keyframes at the beginning of the audio clip and set the Pan knob to the left, after that insert a keyframe at the end of the clip and set the Pan knob to the right. You'll see a line going down from the 1st keyframe to the last keyframe representing the panning change
    4. Or alternatively (in fact faster): position the play head at the start of the clip and change the panning with the knob to left, then place the cursor at the end and change the knob to the right, the keyframes will be inserted automatically
    More information can be found in the manual (search for pan keyframe)
    HTH
    HP Z840 2 x E5-2630V3 8 core, 32 GB RAM, Quadro K4200, AJA KONA LHe Plus w/KL-Box, LSI internal RAID, Win 7 Pro, Avid MC 8.10 w/Symph option [view my complete system specs]
  • Mon, Feb 3 2020 9:48 PM In reply to
    • zefrem7
    • Posts 46
    • Points 580
    Thanks for this! Works great.
