Latest post Thu, Jan 23 2020 12:04 PM by ShadenFreude. 4 replies.
  • Mon, Dec 16 2019 3:57 AM
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 588
    • Points 7,450
    mulitcam causing MC to crash
    Im on 2019.9 and when I started using mulitcam MC started crashing on me. Is there a known bug with multicam? I am ok with updating to the newest version but would like to know if this is fixed before I do.
  • Mon, Dec 16 2019 4:24 PM In reply to
    • Richard
    • Joined on Fri, Aug 17 2012
    • Los Angeles
    • Posts 51
    • Points 615
    Re: mulitcam causing MC to crash
    I use multi-cam (3 cams) on every project.  All releases through 2019.11 have worked fine.  The only problem I've noticed is slowness and stuttering possibly because my files are sometimes on an external drive connected via USB.  But, overall, multi-cam is fine with no crashes.  I'm no computer expert but to little RAM might be a factor.
    MC2020.6 on home-grown IntelCore i7 3.07GHz, 24GB ram, Quadro K4000 (Nvidia driver 340.84), Win 10 Pro 64, Acer, dual 22" monitors, 2-1TB internal... [view my complete system specs]
  • Mon, Dec 16 2019 4:45 PM In reply to
    dew:
    It would help to know more about the system you're working on.  Which version of Media Composer are you running?  Which specific OS? What processor? What video card? How much RAM? Where is your media stored?
    If you edit your user profile, you can add this information so you don't have to type it all the time.  (Look at the bottom of this post for an example.)
    What is your project format/frame rate, and what is your footage format/frame rate? Is your media imported, linked, or linked & transcoded? If it's imported or transcoded, what resolution?
  • Wed, Jan 22 2020 6:54 AM In reply to
    We have possibly the same problem. We use 3-7 cameras with creating group clip from sequence with multiples shots from each of cameras on every track. Sources are AMA linked Sony XDCAM HD 50i PAL mxf 50 mbit or consolidated ones. If editor uses toggle source/record in timeline with mcam source and /or waveform is showed on (and he understand that it was wrong action) - avid MC slows down and through some minutes - freezes and crashes, otherwise editor relaunches MC to fix this speed issue .
    11 PCs HP Z6, AVID MC 2018.12.10, MC 2019.7 [view my complete system specs]
  • Thu, Jan 23 2020 12:04 PM In reply to
    In settings, give Media Cache/video more RAM.  That helps for me.
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440/800/820 PC's on W7/10 x64. 3 x Mac, 4 x PT 2019.12 HDX, S6 , X-MON, all on PCs. NEXIS E4 & ISIS 5000 X... [view my complete system specs]
