Latest post Wed, Sep 25 2019 12:10 PM by MikeyB. 3 replies.
  • Wed, Sep 25 2019 7:30 AM
    Sync Audio to Audio file by waveform
    I have an audio recorder which is timecode-synced to my camera.
    I can sync everything by timecode in avid.
    Now I have to sync a backup file from an audio recorder to the audio from my recorder, which was timecode-synced to the video.
    Can i sync audio to audio directly? Avid says it needs at least one video file?
    MediaComposer 2020, macos catalina, Macbook Pro [view my complete system specs]
  • Wed, Sep 25 2019 9:23 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 513
    • Points 6,380
    Re: Sync Audio to Audio file by waveform
    You can sync 2 audio clips together by waveform analysis using Group Clips. Would this do for you?
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Wed, Sep 25 2019 11:02 AM In reply to
    thanks! How can I do this?
  • Wed, Sep 25 2019 12:10 PM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 513
    • Points 6,380
    Put them in a bin together, select them both and then choose Group Clips from the Clip menu, or shift/command/g, or right-click the selection and choose Group Clips...
    The dialogue is pretty self-explanatory.
    You end up with a Group Clip (obviously!) which contains both audio clips. When you edit with it, you can right-click in the timeline to choose which member of the group is output.
    The default audio is whichever clip was topmost in the bin. So sort if you have a preference, arrange to sort the bin
    contents appropriately before you make the Group.
