Latest post Fri, Jun 12 2020 6:04 PM by DJFio[DB]. 86 replies.
Page 3 of 6 (87 items) < Previous 1 2 3 4 5 Next > ... Last »
  • Tue, Sep 3 2019 4:37 AM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 158
    • Points 1,855
    Re: Blend modes - homemade avx
    OK then, everybody should donate at least $25! This is just too good to not be compensated.  Great job and thanks!
    Primary System: Media Composer 2018.12.8 w/Symphony Option | Phrase Find | Avid Artist DNxIO | iMac 2019 i9 8-Core 3.6/128GB/2TB-SSD/Radeon Vega 48/OS... [view my complete system specs]
  • Wed, Sep 4 2019 5:00 PM In reply to
    • mnbkyle
    • Joined on Tue, Sep 15 2015
    • Minneapolis, MN
    • Posts 60
    • Points 685
    I feel I am missing something to get this installed. When I open the AVX2xBlend Plug-in File, it launches Avid automatically, but does not appear in the Effect Pallette. Anyone else run into this? I'm curious to try this out!
    Kyle
    ISIS 5500 4.7.13, Avid Media Composer various versions. z840, z420, imac trashcans [view my complete system specs]
  • Wed, Sep 4 2019 5:14 PM In reply to
    You have to drop the .avx file into the AVX2_Plug-ins folder and then launch MC.
    I'm on a PC today, so I'm unsure of the exact path for the folder on a Mac, but the PC folder is
    C:\Program Files\Avid\AVX2_Plug-ins
    So, I would guess the Mac would be something like Applications\Avid\AVX2_Plug-ins
  • Wed, Sep 4 2019 9:20 PM In reply to
    • mnbkyle
    • Minneapolis, MN
    • Posts 60
    • Points 685
    ah ha! Thank you!
  • Thu, Sep 5 2019 6:44 AM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 193
    • Points 2,320
    It crashes my avid 8.3 on osx 10.11.6 on startup and the system wants to create a crashlog. :(
    Thanks Andre.
    MAC OS X 10.11.6 AVID MC 2018.3 + Avid Mbox Pro 3 MACBOOKPRO 15" Retina, i7 2.66 GHz Quadcore, 16GB Ram Dell UltraSharp U2711 Sony FS5 & Alpha... [view my complete system specs]
    Honestly I hate editing.
  • Thu, Sep 5 2019 12:21 PM In reply to
    • Posts 11,268
    • Points 231,960
    andre
    can you email me the issue and crash log?
  • Fri, Sep 6 2019 11:07 AM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 193
    • Points 2,320
    Sure, thanks for your help.
    Andre.
  • Fri, Sep 6 2019 11:16 PM In reply to
    Has anyone else noticed an increase in render times with Beta3?
    I have a short 2 minute sequence stacked as follows
    V1: photos (30 frame dissolves between)
    V2: color effect (saturation set to 0)
    V3: BCC Gaussian Blur
    V4: Avid title (using as a solid color matte - i stripped the title effect off)
    V5: Matte Key text layer (pngs rendered from After Effects imported with alpha channel)
    I placed the Blend-X plugin on the V4 clips and set it to render and it was creeping along saying it would take upwards of 1 hour for this 2 minute sequence.
    I disable the V4 track in the timeline and render and it finishes within a reasonable amount of time given the effects stacked.
  • Sat, Sep 7 2019 1:04 PM In reply to
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 328
    • Points 4,345
    Kenton , as you already own BCC, try to compare BCC composite vs blend-x speed inside same sequence and report back. I never tried to compare , but it’s very interesting.
    my zoo: NEXIS Pro 40 tb sw v19.12.0.5; MBPro_late_2013 15'' i7 16GBram OSX 10.15.3 MC 2020.4 BMD US monitor (or AJA io XT ), ATTO NT11;Baselight... [view my complete system specs]
    DJFio[DB]
  • Mon, Sep 9 2019 2:56 PM In reply to
    So, this morning I cleared the renders on my sequence and then rendered with the BCC Composite effect (soft light).
    Then I cleared renders again, removed the BCC Composite and placed Blend-X (soft light) on the sequence. I also modified the magic slider a little.
    With BCC Composite the render took 4:33
    With Blend-X I killed the render after it had been running for 17 mins
  • Mon, Sep 9 2019 3:07 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 328
    • Points 4,345
    Thanks Kenton. Could you provide some more info for my science:)
    which OS and MC version do you use?
    what was the target resolution ,  codec and did you used any special settings for “render bit depth ?”
    DJFio[DB]
  • Mon, Sep 9 2019 3:22 PM In reply to
    Sorry, I should know better about providing my testing specs.
    This system is Win10, MC 2018.12.6. I'm rendering as DNX145 in a non-Interplay shared environment. No special settings for bit depth etc.
  • Mon, Sep 9 2019 3:36 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 328
    • Points 4,345
    Thank you Kenton. I’ve made some experiments but on MacBook Pro 2017 and Mc 2019.x - the render times are better in newer blendX betas but surely must be improved much more.
    DJFio[DB]
  • Fri, Sep 13 2019 2:27 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 328
    • Points 4,345
    addinski:
    Thanks Andre.
    I found and squashed this bug. :) Thanks to your feedback.
    Wait for blendx- beta4 - it will be there soon
    DJFio[DB]
  • Fri, Sep 13 2019 4:08 PM In reply to
    • Max
    • Joined on Mon, Oct 11 2010
    • Milan - Italy
    • Posts 6
    • Points 80
    You're great!
    Years ago MDV, today xBlend (or maybe Blend-X).
    Just test it here @office on 2018.1/Win10.
    Seems working fine but I've a question for you: I'd like to use screen blending-mode on a AMC generated Title or on a clip that has it's alpha-channel...
    Can it be done?
    Hope you'll refresh MDV for Windows sooner or later...
    A big thanks!
    Max
    Avid Media Composer 8.2 / HP Z820 Workstation / 2x Intel Xeon E5-2630 v2 @ 2.60 GHz / Nitris-DX / nVidia Quadro K4000 / 16GB ram / 1x8 TB SAS Raid unit... [view my complete system specs]
