Latest post Mon, Aug 19 2019 1:56 PM by mmullen. 3 replies.
  • Thu, Aug 15 2019 3:07 PM
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    Transcode fails thinking the output file is 10 times larger than it really is
    Tracking down an issue where transcodes are failing because it thinks the output files are larger that the available space which isn't true.
    Running a large transcode of XAVC Intra 4K clips to DNxHR LB
    The transcode screen shows that we need about 180GB.  Allows me to proceed and the transcode progress bar comes up and hangs for 30 seconds to a minute.
    After an error comes up stating that there is not enough space for a file of 1.8TB.
    If I do it in chunks it works and the files are indeed about 180 GB, not 1.8TB.
    Mac OS 10.14.6
    MC 2018.12.3
    Seen running the transcode to shared storage and local as the destination. Has anyone seen this before?
    -Matt M.
  • Thu, Aug 15 2019 8:39 PM In reply to
    • Posts 11,309
    • Points 232,400
    Re: Transcode fails thinking the output file is 10 times larger than it really is
    Matt
    First, I cant even try this out as 10.14.6 isnt approved and tested with 2018.12.3
    2019.12.3 is for macOS v10.12.6, 10.13.6 and 10.14.3
    Can you upgrade to 2018.12.7 as a few transcode bugs were resolved.....
  • Thu, Aug 15 2019 9:02 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    Will give it a shot and report back.
    I have narrowed down that it happens only when Keep sources frame rate is selected.  When selecting Convert to project frame rate and using DNX36 it transcodes without issue.
    -Matt M.
  • Mon, Aug 19 2019 1:56 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,560
    This does still happen on:
    2018.12.7 and 2019.7
    -Matt M.
