Latest post Thu, Aug 1 2019 4:05 AM by sebondar. 3 replies.
  • Fri, Jul 19 2019 4:36 PM
    • sebondar
    • Joined on Thu, Jul 29 2010
    • Posts 12
    • Points 155
    5120x2160 in 2019 Media Composer
    Can anyone help? I selected the 5120x2160 in source browser (footage shot on Scarlet W dragon sensor in anamorphic), but my 2019 Media Composer Ultimate composer window stretches the image even though the composer is selected to 16x9. When I switch from UHD to 1080p 23.98 in project settings it does the same 4:3 aspect ration. It's my first time working with 5k, so maybe Avid UHD is designed for 4k, 8k, 16k (not 5k)? This is my punishment for spending too much time in Resolve.
  • Fri, Jul 19 2019 6:06 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 695
    • Points 7,830
    Re: 5120x2160 in 2019 Media Composer
    when i started recently to work with anamorphic adapters, it took me a bit of experimenting before i found, what i believe, works best for me.
    when i start a project, i use my custom format: 6324x2496
    that correspond to a 1.9:1 aspect ratio - it looks better in my eyes that the expected 2:1 ( i blame it on my 2:1 adapter :-)
    once the footage in linked in my folder, i access the frameflex page and tweak my aspect ratio as needed.
    interestingly, i end up with the same image with the two different methods showned in the examples attached.
    planning on finishing a couple projects in that format and will convert to smaller files later, as needed.
    (lumix gh5 in anamorphic mode 4:3, nikkor lens with isco ultra star+ red 2:1 and rapido single focus adapter)
    symphony 2020.12 - win 10 pro64 v.1909 - nVidia gtx1080 OC (460.89 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2 - MSI X99A - 112GB... [view my complete system specs]
  • Fri, Jul 19 2019 6:09 PM In reply to
    • touviere7
    • los angeles
    • Posts 695
    • Points 7,830
    second image
  • Thu, Aug 1 2019 4:05 AM In reply to
    • sebondar
    • Posts 12
    • Points 155
    Thank you for the reply. Your custom project suggestion worked. However, I decided to edit this in a 1080p timeline. So, I just unsqueezed the anamorphic wide by adding pillarbox in Source Settings> Reformat.
