Latest post Wed, Jul 3 2019 9:10 PM by Robert A. Ober. 3 replies.
  • Tue, Jul 2 2019 11:37 PM
    • dmc33
    • Posts 6
    • Points 90
    I'm tired. I'm an idiot. I freely admid it. I just want to stop the CTI
    Hello:  OK. I just launched the new media composer.  The CTI returns to its playback origin when I hit the space bar to stop it.  What's the shortcut to have it behave "normaly"and stop in the timeline when you hit the space bar. Thanks.  Are there other changes to seemingly normal basic performance behaviors?  Thanks foe any help.  Dan.
    Am I so hopelessly lost that nobody thinks this question warrents an answer or, have I stumbled into something where nobody knowes the simple answer?  There has to be a simple keyboaed shortcut "toggle" that determines the behavior of the CTI.
  • Wed, Jul 3 2019 12:29 AM In reply to
    Re: I'm tired. I'm an idiot. I freely admid it. I just want to stop the CTI
    In your user settings go to the Timeline settings and then the Edit tab.  You can see a Position Bar Snap option there I believe this should not be checked.   The note says that checked theposition bar snap to nearest event or segment start. (checked on MC 2018.12.6 not the latest 2019.6)
    Alayne
  • Wed, Jul 3 2019 5:45 AM In reply to
    dmc33:
    There's not a setting that changes the behavior of the position indicator. It should just stay wherever it is when you stop playback, so something is wrong.
    Are you using v2019.6? If you are, did you create a brand new user, or are you using an old user setting that you brought forward from an older version of Media Composer? If it's an old setting, try creating a new user and see if the problem persists.
  • Wed, Jul 3 2019 9:10 PM In reply to
    From the Help:
    Position Bar Snap
    When this option is selected, clicking in the Timeline will snap the position indicator to the nearest event, such as IN and OUT points, markers, and segment start and end points.
    So what is CTI ?
    Robert
    2018 MacBook Pro,I7 2.6GHz/32GB RAM/Radeon Pro 560X 4GB/500GB SSD/External RAID0/Mojave & MacPro Early 2009 24GB/GTX1080Ti/1GB SSD/HIT2TB/WD1TB/ProAvio... [view my complete system specs]
    Robert A. Ober
    IT Consultant, Vidcaster, & Freelance Preditor(Producer/Editor)
    www.infohou.com
    Houston, TX
