Latest post Sun, Jun 30 2019 6:54 PM by AntCaladine. 2 replies.
  • Sun, Jun 30 2019 5:48 PM
    • zonik
    • Joined on Sat, Jan 15 2011
    • Posts 30
    • Points 505
    Frameflex Z-Rotation to get 16:9 to 9:16
    I was unable to rotate 3840x2160 90° to 2160x3840.
    While Frameflex rotates the Image as expected it crops parts of it no matter of what settings I've tried.
    Project is set to 2160x3840.
    It could be done correctly if the scale-slider would have a wider range. But I did find no way to do it.
    So I did what was suggested elsewhere and used DaVinci Resolve to simply rotate my footage by one klick.
    If there is a solution within MediaComposer, please tell me. If not, please fix it.
    It's not for a niche it's a social media format.
    Media Composer 8.8 Windows 10 Pro [view my complete system specs]
  • Sun, Jun 30 2019 6:47 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 411
    • Points 5,600
    Re: Frameflex Z-Rotation to get 16:9 to 9:16
    You can do that in a few seconds in AvidFX/BorisRed. I can't believe they EOL that as being part of MC.
    MC 2018.10 w/Symphony option. NitrisDX, HP Z800 Dual 2.67Ghz, 500GB SSD, 96GB Ram, Nvidia M4000, BCC2019, Sapphire2019, TitlePro5, ProTools 10.5,Terrablock... [view my complete system specs]
  • Sun, Jun 30 2019 6:54 PM In reply to
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 373
    • Points 4,720
    Silly question. But why don’t you just edit it 16x9?
    if you have an external monitor just turn it on its side to see.
    then sort out rotation when final encoding.
    if you can’t turn your monitor, then just stick a 3D warp top layer to rotate.
    i do quite a lot of 9:16 content and find this route so much easier than rotating each clip in flex frame.
    2x HP Z8 G4, 96GB ram, Win10 Pro 64bit, Nvidia Quadro P4000 8GB AMC 2019.8 1x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 2018.12.7 2x... [view my complete system specs]
