Latest post Tue, Jul 2 2019 3:07 PM by AntCaladine. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Jun 26 2019 2:46 PM
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 375
    • Points 4,750
    titler+ 2019 scaling bug
    Firstly I'm happy to say titler+ 2019 has had a few tweeks, which almost makes it workable!!
    Centering two lines works, left or right justifcation works, and now with 2019 you can scale your titles!
    Well.....  Maybe not.
    The stepping in the scale. Looks shocking. Firstly I thought maybe needs rendering, but makes no difference.
    Can anyone else do a quick down a dirty test to replicate. Simply titler+ scale from 90-100% over say 2secs.
    2x HP Z8 G4, 96GB ram, Win10 Pro 64bit, Nvidia Quadro P4000 8GB AMC 2020.6 1x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 2020.6 2x Aja... [view my complete system specs]
  • Fri, Jun 28 2019 2:37 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 375
    • Points 4,750
    Re: titler+ 2019 scaling bug
    bump.
    Can anyone with 2019.6 do a quick test for me?
  • Fri, Jun 28 2019 3:17 PM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 513
    • Points 6,545
    AntCaladine:
    bump.
    I don't know if I understand you correctly, but I just did a simple centred title and scaled to 200% and it looks very sharp in full quality mode.
    What I miss is being able to centre both vertically and horizontally, seperately - and to justify within the container as in the old Titler, much quicker and more useful - or maybe I'm missing something, I still reach for the old titler as I'm working in HD.
    MC with Symphony option, 2020.4, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P3200/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio Mini... [view my complete system specs]
  • Fri, Jun 28 2019 3:25 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 375
    • Points 4,750
    I mean to dve the title with titler+
    So a keyframe start and end. First keyframe say 90% second 100%
    For me the dve plays very steppy. Not at all smooth.
    As for centering. Horizontal works great. Cannot do vertical. :(
    Although at least you can manually position it with sliders (called translate not position!!)
  • Fri, Jun 28 2019 3:27 PM In reply to
    • damien78
    • Joined on Tue, Jan 7 2014
    • Geneva
    • Posts 36
    • Points 440
    I did a very quick test and I am not very familiar with Titler+ so it may not be a reliable test. I keyframed the Scale parameter of Layer 1 (Text) from 90 to 100. If it is what you intended to test, it ended upon my station with a strange jaggy animation, not very pleasing and useable indeed...
    Media Composer 2019.6, w/Symphony/SS/PF options, MAC PRO 2013 3.5 GHz 6-Core Intel Xeon E5, ATI FirePro D500 3072 Mo, 64 GB RAM, MacOS 10.14.5, AJA LHi [view my complete system specs]
  • Fri, Jun 28 2019 3:30 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 375
    • Points 4,750
    Sound like your seeing what I am.
    If you repeat with the old title tool, you should get a nice smoth dve.
  • Fri, Jun 28 2019 3:35 PM In reply to
    • Posts 11,268
    • Points 231,960
    On it and will get suppport to reproduce
  • Fri, Jun 28 2019 3:45 PM In reply to
    • Posts 11,268
    • Points 231,960
    Ant.....      I have a case going for you...  #03735945 .......
    Danien78.... I have created a case for you # 03735954   as the more we enter the higher the priority to fix if they can reproduce it. :)
  • Fri, Jun 28 2019 4:10 PM In reply to
    • Mercer
    • UK
    • Posts 513
    • Points 6,545
    AntCaladine:
    Yes exactly the same behaviour here as you - very bad indeed.
  • Tue, Jul 2 2019 3:07 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 375
    • Points 4,750
    Confirmed bug - MCCET-3096
    Hopefully engineering can find a fix soon.
