Latest post Thu, Nov 21 2019 2:44 PM by postman91602. 37 replies.
Page 2 of 3 (38 items) < Previous 1 2 3 Next >
  • Tue, Jun 25 2019 1:20 PM In reply to
    Re: Media Composer v2019.6 -- NOW AVAILABLE -- w/new UI
    That was on my home computer. Now, at work, with a different Mac and a different NewBlue account, I get the same error:
    Unable to activate because of failure to communicate with AvidELF.
    p, li { white-space: pre-wrap; }
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2019.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.14.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Thu, Jun 27 2019 10:46 AM In reply to
    These problems have magically gone away after a couple of days on both systems. Weird.
  • Mon, Jul 15 2019 4:16 AM In reply to
    • Mikej
    • Joined on Tue, Nov 13 2018
    • Posts 12
    • Points 135
    Where have all the timeline tools gone? I can't find how to edit transitions anymore...
    These tools:
    iMac (Retina 5K, 27-inch, 2017), 4.2 GHz Intel Core i7, 32 GB 2400 MHz DDR4, Radeon Pro 580 8 GB [view my complete system specs]
  • Tue, Jul 16 2019 11:08 PM In reply to
    • Mikej
    • Posts 12
    • Points 135
    Mike Jeffery:
    These tools:
    I've realised the smart tools on the timeline have gone the way of the dodo, so I've had to remap them to (a vastly decreased amount of) mappable buttons...
  • Wed, Jul 17 2019 8:47 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    They are common buttons now. Segment and trim tools with right-click options. By default you should find them above the timeline.
    https://youtu.be/i8aMysJ0-f0
  • Wed, Jul 17 2019 8:50 AM In reply to
    The Smart Segment and Trim Tools are accessed by a right-click. Transition effect adjustment seems to be on by default. Make sure you create entirely new user settings and also trash the old site setting file or you may not see the correct UI.
  • Wed, Jul 17 2019 11:09 PM In reply to
    • Mikej
    • Posts 12
    • Points 135
    Thanks for this - turns out I havent been seeing the correct UI and had to map these myself manually.. Didn't realise we had to trash all our old settings and start from scratch *sigh*
  • Thu, Jul 18 2019 9:47 AM In reply to
    Right click here (there should be an image)
  • Sat, Jul 20 2019 10:20 AM In reply to
    And (on squinting at the new UI), the button to toggle transition effect adjustment is right there in the Timeline Toolbar. With the very limited highlight colours in this version it is very difficult to tell which button is highlighted.
  • Mon, Jul 29 2019 1:25 PM In reply to
    • rolfio
    • Joined on Mon, Feb 14 2011
    • Posts 21
    • Points 290
    Still the problems are not solved with the Subcap font styling. In 8.9.4 this works fine. In the latest version the settings react completely different. The space between the letters is to big for example when using helvetica neue 67 (standard broadcast subtitle font). Can you please add support for letterspacing in the next release so we can control the font in any way.
  • Mon, Jul 29 2019 2:14 PM In reply to
    • Posts 11,210
    • Points 231,200
    rolfio:
    Can you email me this info and your System ID please so I can get a case started and a bug logged.
  • Thu, Aug 1 2019 12:37 AM In reply to
    • Mikej
    • Posts 12
    • Points 135
    Is anyone else having an issue in the new UI where both source and timeline windows are blank black screens on first load of Edit workspace in a project? Switching to Colour workspace brings everything back up and then switching back to Edit it's good to go. Not a huge issue but a little annoying...
  • Fri, Aug 2 2019 1:28 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,149
    • Points 23,925
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hello Mikej,
      You must create a new user. Select File > Settings, click the User tab and create a new User Profile after upgrading to the latest MC, What OS version do you use?
    RalphC
  • Sun, Aug 4 2019 11:11 PM In reply to
    • Mikej
    • Posts 12
    • Points 135
    Thanks Ralph. I am currently on 10.13.6
  • Tue, Aug 6 2019 1:30 PM In reply to
    • RalphC
    • Posts 2,149
    • Points 23,925
      Avid Employee
    What is the result of the new profile settings?
    RalphC
