Latest post Thu, Nov 21 2019 2:44 PM by postman91602. 37 replies.
Page 1 of 3 (38 items) 1 2 3 Next >
  • Thu, Jun 20 2019 7:23 PM
    Idea [I] Media Composer v2019.6 -- NOW AVAILABLE -- w/new UI
    Avid is pleased to announce the latest release of Media Composer v2019.6 on June 20th, 2019. The software is available through My AvidAvid Link, or the Download Center (login and password required). You must have a current Support & Upgrade plan to run the latest software.
    + OS SUPPORT:
    This release is supported on macOS 10.14.5 (Mojave), 10.13.6 (High Sierra), and 10.12.6 (Sierra).
    + NEW FEATURES:
    - Redesigned User Interface (UI) and User Experience (UX)
    - Media Composer | Distributed Processing
    - Media Composer | Enterprise
    - Workspace Toolbar
    - MXF OP1a Media Creation
    - OpenEXR support
    - IMF Support
    - 32-bit Floating Point Quality
    - Support for ACES Workflows
    …and others.
    + 3RD PARTY STORAGE CUSTOMERS:
    An issue has been identified when creating new projects in a 3rd party shared storage environment. Despite the dialog box to emulate a NEXIS system, the correct setting is not automatically changed. After the project is open, go to Settings > Project > General and check “Enable Bin Sharing on 3rd Party Storage Emulating NEXIS/ISIS.” You can then proceed as normal and this setting will stick for the project.
    + CREATE A NEW USER SETTING:
    With all of the changes to the UI, users MUST create a new user setting for this software version.
    + FOR MORE INFORMATION:
    See the ReadMe or What's New documents published on the [link=http://http://avid.force.com/pkb/articles/en_US/user_guide/Media-Composer-2019-Documentation[/link] prior to upgrading if you have any questions.
    If you have general issues with installing or running the release, post them here. If you think you have found additional bugs, please start a new thread.
  • Thu, Jun 20 2019 10:07 PM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 153
    • Points 1,875
    Re: Media Composer v2019.6 -- NOW AVAILABLE -- w/new UI
    As I have afraid of, the new Avid does not support 2 monitors workflow when monitors have different resolution. Of course, I can't expand workspace toolbar to second monitor but I can use floatong windows on that monitor.
    But Avid can't remember their position. Every time I close and open Avid all floating windows jumps to first monitor in random position.
    That's bad. Please mark it as a bug!
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Thu, Jun 20 2019 10:25 PM In reply to
    • Posts 11,260
    • Points 231,840
    Gorky
    A lot of folks are using it and it works and even remebers ... did you create a new user profile.....
    Can you rearrange the 2 displays in the Mac System Preferences, so that the 2nd screen doesn't become the #1 display as Avid sees it. So just place off of the bottom right corner of your center display. This way Avid sees it as #2 in the available displays. Then it automatically placed the "host" panel into the left UI screen.
  • Thu, Jun 20 2019 11:46 PM In reply to
    so can you not tab and dock windows on the second monitor if its different resolution? This makes alot of trouble for users with 27inch 5k imacs and a secondary screen if so.
    I like to have my source / record windows, bins and audio mixer on one screen  and my timeline, effect pallete and audio tool open on the other screen. Is this still possible and can I take advantage of the tabbing still?
  • Fri, Jun 21 2019 11:41 AM In reply to
    • gorky
    • Posts 153
    • Points 1,875
    Thank you, Marianna.
    After first barrier digging deeper...
  • Fri, Jun 21 2019 12:36 PM In reply to
    • gorky
    • Posts 153
    • Points 1,875
    In some windows, for example Expert Render InOut - some text does not fit in small window.
  • Fri, Jun 21 2019 1:37 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 395
    • Points 4,680
    Hey Marianna,
    Should we expect updates to compatibilty documents for media composer 2019.x with nexis/interplay/mediacentral compatibility to drop soon?
    Dave
    "A very big network"
  • Fri, Jun 21 2019 4:30 PM In reply to
    • Posts 11,260
    • Points 231,840
    Let me check NYnutz.
  • Fri, Jun 21 2019 7:04 PM In reply to
    • Posts 11,260
    • Points 231,840
    NYnutz...
    I have been told they are working on them and should have something to post next week.
    I would subscribe to the KB articles you expect to get updated so the min they do, you are notified.
  • Mon, Jun 24 2019 11:45 AM In reply to
    • NYnutz
    • New York City
    • Posts 395
    • Points 4,680
    Thanks Marianna!
    Dave
  • Mon, Jun 24 2019 2:40 PM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 513
    • Points 6,380
    You definitely can tab and dock windows on a second monitor of different resolution - I have been doing so on my system without difficulty
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Mon, Jun 24 2019 11:57 PM In reply to
    So on Mojave 10.14.4 Upon launch we get the "application is not optimized" for mac message. Brand new computers so no OS downgrade options. Now leary of updating to 10.14.5.......
    Most are New MacPro 12 core or 8 Core 2012 MacPros with 24+ Gb Ram nvidia gtx 1070 [view my complete system specs]
  • Tue, Jun 25 2019 8:43 AM In reply to
    Since going to 2019.6 and testing, I get a watermark on my NewBlue titles. I'm logged in correctly in the NewBlue App Man but I get an error:
    iMac i5 27", 40GB RAM, OS 10.14.6 with Symphony 2020.6, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.14.6 with MC 2018.12.12 and BMD... [view my complete system specs]
  • Tue, Jun 25 2019 8:44 AM In reply to
    You don't only need new user settings but also trash your Site Setting file before installing and launching. If not, the UI will be missing some elements.
  • Tue, Jun 25 2019 9:14 AM In reply to
    The edit and small tool palette buttons have been removed from the centre of the Composer window. That's OK but the small tool palette icon should be in the Timeline toolbar by default, as should the Render button (also missing). Yes - I have made new settings!
