Latest post Thu, Jul 25 2019 12:40 PM by ShadenFreude. 39 replies.
Page 2 of 3 (40 items) < Previous 1 2 3 Next >
  • Fri, Jun 21 2019 2:05 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 133
    • Points 1,520
    Re: Media Composer 2019.6 AVAILABLE NOW - 20 June 2019
    Hi Dale,
    Strange that your Mojo DX isn't working under 2018.12.3. I have a system running on that with a Nitris DX right now.
    I'm not familiar with OS-X Mojave because my old machine doesn't allow me to install that anmore. Sorry!
    Maybe you better contact support and make a case.
    Ivan
    Avid Media Composer 2018.12.3.51505.0 | Avid Symphony Option | Avid ScriptSync 2.0 | Avid PhraseFind 2.0 | Avid Pro Tools 11.3.1.370 | Avid Application... [view my complete system specs]
  • Fri, Jun 21 2019 2:11 PM In reply to
    • Dale Gagne
    • Joined on Mon, Oct 24 2011
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    It was originally working with 10.14.3 and 2018.12.3 no problems at all. But then I upgraded to 10.14.5 and 2019.6 and then nothing worked. After which I tried downgrading ONLY the avid software back to 2018.12.3 and still the Mojo didn't work although I know that 2018.12.3 isn't qualified on 10.14.5.  I uninstalled every version from 2019.6-2018.12.3 on os 10.14.5 and mojo would not resync until I put in my old boot drive running 10.13.6 and 2018.12.3 which is what I am currently working with....
    Avid MC 2018.12.3, Avid Mojo DX, Mac Pro, Mid 2012, 2x2.4 ghz 6 CORE Intel Xeon, 64GB Ram, SSD Startup, 10.14.0, Radeon RX 580 8g, 9TB Internal Storage... [view my complete system specs]
  • Fri, Jun 21 2019 3:17 PM In reply to
    After the upgrade, you tried to turn off the computer and the mojo and then start a new one.
  • Fri, Jun 21 2019 3:23 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    no..i don't undestand what you mean. Nothing was turned off during the original install. Uninstalled 2018.12.3 , Upgraded OSX from 10.14.3 to 10.14.5 . Installed 2019.6...everything went as expected.
  • Fri, Jun 21 2019 3:32 PM In reply to
    OK. do you have drivers installed on the computer and the device manager indicates that the mojo is connected? Or not.
  • Fri, Jun 21 2019 3:42 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,611
    • Points 65,840
    Nekraschewitsch:
    Agreed, try to cycle power the Mojo, since there's no switch, IIRC, turn off the computer and pull the Mojo plug, wait a bunch of seconds, plug it back in, and start the system. Other than that I think You might get more appropriate answers over the Mac side of the forums.
    peace luca
    • Dale Gagne
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    it said that it had 2019.4 driver installed but the Mojo would not host link to the card...Everythign worked fine except for the HW/SW would not connect the Mojo
  • Fri, Jun 21 2019 3:48 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    also to note. with OSX 10.14.5 installed and attempting to downgrade from 2019.6 once i couldn't get it to work i was downgrading the dx driver that corresponded to the avid version...and still it would not connect. Which is why i think this could be a 10.14.5 issue
  • Fri, Jun 21 2019 3:57 PM In reply to
    Dale,  Try to clean PRAM.
     OptionплюсCommandплюсPплюсR
  • Fri, Jun 21 2019 4:14 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    I did thanks..Tried that. Tried first ait and a clean my mac x ...nothing seemed to work. Burning my solid state boot drive back to original and rebuilding it to see how it goes..
  • Fri, Jun 21 2019 4:25 PM In reply to
    • Posts 10,667
    • Points 223,915
    Dale,
    Is your Mac an i5 or an i7?   I think it is 10.14.5 on your Macbook thats the culprit here but cant be sure....
    Can you post "about this Mac photo"
  • Fri, Jun 21 2019 4:37 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    Hi Marianna,
    Curently had to revert to a High Sierra boot disk i have ready for these situations...But my system is not a mac book it is :
    Avid MC 2018.12.6, Avid Mojo DX, Mac Pro, Mid 2012, 2x2.4 ghz 6 CORE Intel Xeon, 64GB Ram, SSD Startup, 10.14.5, Radeon RX 580 8g, 9TB Internal Storage, Nexis Client Manager 2017 v7.11.0.8
    Image to confirm is attached.
  • Fri, Jun 21 2019 7:24 PM In reply to
    Hi Nekraschewitsch,
       What resolution/percent are your monitors set to?
    I'd like to confirm if they are the same size, and if they are %100 or %200.
    Please let me know.
    ~Keith
    - MacPro, 2.66 GHz, 14G RAM; OS 10.8.4; MC DX Nitris; ISIS 4.5 - MacBook Pro, 2.3 GHz i7, 8G RAM, ISIS 4.5 - z800 Xeon 2.93Ghz, 12G RAM, Win 7, DX Nitris... [view my complete system specs]
  • Fri, Jun 21 2019 10:02 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    Been using the same monitors at this resolution since i bougth them 8 yrs ago
  • Sat, Jun 22 2019 4:43 AM In reply to
    Did you allow the drivers to be installed in System Pref -> Security?
