Latest post Thu, Jul 25 2019 12:40 PM by ShadenFreude. 39 replies.
Page 1 of 3 (40 items) 1 2 3 Next >
  • Thu, Jun 20 2019 4:27 PM
    Media Composer 2019.6 AVAILABLE NOW - 20 June 2019
    Media Composer 2019.6 is available today, June 20, 2019 @ 12:00 noon.
    Status of Support Plan:  The ability to launch Media Composer 2019.6 software is dependent on the status of your Upgrade and Support Plan on June 20th, 2019.
    Location at Launch: Media Composer 2019.6 is available from Avid Link, MyAvid and the Avid Download Center (login and password required).
    User Profile:  Avid recommends that users make a new user profile under version 2019.6. Do not attempt to carry over a user profile from an older version.  This will avoid “potential issues”.
    What’s New in Media Composer 2019.6:  The following are new with this release.
    -  Media Composer | Distributed Processing
    -  Media Composer | Enterprise
    -  Updated User Interface
    -  Change to Digital Audio Scrub
    -  Workspace Toolbar
    -  The Inspector
    -  Multiple Monitor Support
    -  MXF OP1a Media Creation
    -  OP1a MXF Mixdown
    -  OpenEXR Support
    -  IMF Support
    -  Support for 32 bit Floating Point Quality
    -  Timeline - Full Floating point (32 bits) Processing Support
    -  Support for ACES Workflows
    -  Source Settings Color Encoding Update
    -  Dynamic Relink Across Frame Rates
    Media Composer 2019.6 Documentation:  Linked right here (thanks, Luca!):
    http://avid.force.com/pkb/articles/en_US/user_guide/Media-Composer-2019-Documentation
    The “What’s New” and  “ReadMe” documents for this release of Media Composer 2019.6 have also been uploaded to the Download Center today, June 20, 2019.  Please READ the “What’s New” and “ReadMe” prior to installing and using the product.  This new version has changed and is vastly different than past releases so reading these documents and educating is important before using this product.
    Changed in Media Composer v2019.6:
    -  (Windows):  If you are installing the editing application and you have a previous version of the editor on your system, go to the Control Panel and manually uninstall the editing application before you try and install v2019.6. You might receive a “cannot continue” error if you perform the installation without manually uninstalling first.
    -  MCDEV-11537: If you intend to use full-frame stereoscopic with an Avid Artist DNxIQ, you may want to remain with Media Composer 2018.12 until the issues with stereoscopic support are resolved in a future version.
    -  NVIDIA drivers: NVIDIA drivers are no longer included with the Media Composer installer. You must access the  Nvidia website - Nvidia.com to download the applicable driver. See the Compatibility Chart in the ReadMe page 30 for supported driver version with this release.
    Limitations:  Listed below are the known limitations in Media Composer v2019.6.
    -  Enable 3rd Party Emulation Warning:  If you launch a project and receive an "Enable 3rd Party Emulation" warning, even if you select Enable in the warning dialog, you must also perform the following: Select File > Settings and click the Project tab. Click General Settings and select “Enable Bin Sharing on 3rd party storage emulating Avid NEXIS/ISIS.
    -  Bug Number: MCDEV-11197. In some instances, the Interleave option might not appear in the Export As dialog box. If you are performing an Export using the Avid Media Processor, the Interleave option should appear when you choose Stereo, 5:1, or 7.1 Audio. Workaround: If it does not appear, briefly toggle back to the Mono setting, then toggle to Stereo Mix once again. Doing so should reveal the Interleave option.
    -  Bug Number: MCDEV-8641. (AMD Graphics). Systems with AMD graphics cards might display tearing when performing Full Screen playback.
    -  Bug Number: MCDEV-9460. Windows 7 systems with Nvidia Maxwell or Nvidia Pascal cards might experience playback issues that could result in “Play Consumer timeout” errors. Workaround: Select “Disable GPU Effects” in the Render Settings dialog box.
    -  Bug Number: MCDEV-9269. (Media Composer | Cloud) After performing a remote download operation on a sequence containing AVC-I 100 remote media, the downloaded media appears as XAVC-I 100.  Workaround: Download the entire master clips.
    -  Bug Number: MCDEV-9011. Intermittently, when working with the XDCAM Nablet Plug-in, you might see “Failed to get the sample position from the AMA Plug-in” errors if you have waveforms enabled in the Timeline.
    -  Bug Number: COGS-2560. While working in the Script Window, text operations (cut/copy/paste/delete/editing) can only be done in edit mode. See “Editing a Script” in the Help.
    -  Bug Number: MCDEV-5650. When working with Panasonic LongG media, you might receive an “SFPlayConsumer Timeout” error if audio waveforms are enabled. Workaround: Turn off audio waveforms.
    -  Bug Number: MCDEV-5385. MultiCam editing with Panasonic LongG media is not supported with this release.
    Media Composer 2019.7 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Thu, Jun 20 2019 5:12 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 400
    • Points 5,220
    Re: Media Composer 2019.6 AVAILABLE NOW - 20 June 2019
    Using the installer downloaded from MyAvid account, I'm getting a Windows Installer error after it finishes installing Avid Link. I did uninstall 2018.12.5, and rebooted.
    System:
    HP Z840
    Windows 10 Enterprise v1809
    Ideas?
    Avid Media Composer 2019.6 Symphony option, Avid Artist DNxID (DNxID Desktop Video Application v11.0), macOS 10.14.5, iMac Pro (2017) 10-Core, 3.0GHz Intel... [view my complete system specs]
  • Thu, Jun 20 2019 5:29 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 131
    • Points 1,500
    Yep, and already downloading! Big Smile
    Avid Media Composer 2018.12.3.51505.0 | Avid Symphony Option | Avid ScriptSync 2.0 | Avid PhraseFind 2.0 | Avid Pro Tools 11.3.1.370 | Avid Application... [view my complete system specs]
    My old Avid forum account: ISDV
    • jdrouette
    • Vancouver, Canada
    • Posts 400
    • Points 5,220
    I solved my own problem by moving the installer files to the system drive and installing from there.
    For some reason, installing from our Facilis shared storage did not work for this version even though it had for previous ones.
  • Thu, Jun 20 2019 5:43 PM In reply to
    Great, thanks to avid team for the new version!
    Already installed and starting testing :-)
    Uninstalling old version (2018.12.3) prior to installing the new worked flawlessly on my test machine.
    Have fun everyone,
    greetings,
    Felix
    Avid MC 2018.12 / NitrisDX / HP z840 / Windows 10 Pro 64bit / winVer 1803 / Interplay - Media Central Production / ISIS 5500 storage / Client connection... [view my complete system specs]
  • Thu, Jun 20 2019 6:32 PM In reply to
    • Posts 10,607
    • Points 223,200
    jdrouette:
    jdrouette
    That is noted in the ReadMe under limitations.  we just reproduced that today thanks to Kevin klimek, one of our moderators.
    HTH and ping me in a weeks time so I can update you on the issue.
  • Thu, Jun 20 2019 7:02 PM In reply to
    • cls105
    • los angeles
    • Posts 443
    • Points 5,795
    I am very excited about Distributed Processing.
    I am just an editor who works from home and I hope I do not need Media Central for this.
    Can someone elaborate on the requirements for this since the Distributed Processing documentation is currently "coming soon"
    Thank You
    MC 2018.12.1, diy x299 7940x 4.7ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
  • Thu, Jun 20 2019 7:15 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,652
    • Points 46,850
      Moderator: MCA Mac
    The documentation is online. If you follow the links through the readme, you'll end up at the PDF. The direct link is at:
    resources.avid.com/SupportFiles/attach/Media_Composer_Editing_Guide_2019.x.pdf
    edit: Sorry, should have read more closely: you were looking for the distributed processing doc's.
    Dave S.
  • Thu, Jun 20 2019 7:20 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,652
    • Points 46,850
      Moderator: MCA Mac
    cls105:
    Sorry, but you need a Nexis and Media Central to make distributed processing work.
    Dave S.
  • Thu, Jun 20 2019 7:26 PM In reply to
    • cls105
    • los angeles
    • Posts 443
    • Points 5,795
    DStone:
    cls105:
    Sorry, but you need a Nexis and Media Central to make this all work.
    slightly frustrating.  All the nab videos make it seem like all this stuff will be accessible for editors who work alone (there was no mention of media central if I recall) but when its all said and done, of course its not.
    Can someone suggest the cheapest most bare bones config for media central to make distributed processing possible.  thanks
  • Fri, Jun 21 2019 12:49 AM In reply to
    • Dale Gagne
    • Joined on Mon, Oct 24 2011
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    This is not seeing my mojo....is there an installer i can run to fix this?
    Avid MC 2018.12.3, Avid Mojo DX, Mac Pro, Mid 2012, 2x2.4 ghz 6 CORE Intel Xeon, 64GB Ram, SSD Startup, 10.14.0, Radeon RX 580 8g, 9TB Internal Storage... [view my complete system specs]
  • Fri, Jun 21 2019 5:42 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,610
    • Points 65,805
    camoscato:
    Media Composer 2019.6 Documentation:  The “What’s New” and  “ReadMe” documents for this release of Media Composer 2019.6 will be uploaded to the Download Center today, June 20, 2019.  Please READ the “What’s New” and “ReadMe” prior to installing and using the product.  This new version has changed and is vastly different than past releases so reading these documents and educating is important before using this product.
    I've had a hell of a time hunting for the Readme and What's new files, I could be dumb, and call me lazy, but I miss the times when new release announcements used to provide links to such documents. This is for anyone looking for the docs
    peace luca
  • Fri, Jun 21 2019 11:53 AM In reply to
    Project in PAL, but shows NTSC. Only with a new project this will be displayed correctly. In window text not displayed correctly.
    System:
    HP Z440
  • Fri, Jun 21 2019 12:35 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 131
    • Points 1,500
    Dale Gagne:
    You need to install the DX-drivers seperately. You can do this when installing Media Composer or later. On the install there is a box you have to tick because the DX-driver is not installed anymore as standard.
    As you already installed Media Composer you need to navigate to: (Windows) Program Files\Avid\Utilities\DXDrivers
    Hope this helps!
    Ivan
  • Fri, Jun 21 2019 1:29 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 142
    • Points 1,550
    Hi Ivan,
    I did do that at the time of initial install and tried again uninstalling and installing dx drivers separately. Neither worked to see my mojo dx. Would not host link.
    I then tried to back track to 2018.6 all the way back to what I was previously running which was 2018.12.3 and the mojo would not work. I then had to revert to a clone bk drive I made before this update and that worked fine which confirms it is a software thing somewhere. I am tending to think 10.14.5 may be the issue as I did update the OS to the qualified 10.14.5 prior to updating Avid to 2019.6....May try 2019.6 with OSX 10.14.3 as that OS was working before...
    Any other thoughts? Do I need to run the Blackmagic codec with the Mojo DX when on 2019.6 and 10.14.5?
    Dale
