Latest post Sun, Jun 16 2019 10:07 PM by Dwight . 2 replies.
  • Sun, Jun 16 2019 5:39 AM
    • Dwight
    • Joined on Thu, Aug 26 2010
    • Buhler
    • Posts 80
    • Points 1,060
    I am submitting a screening version of a 12 minute short film I edited to a local film festival. I'm attaching a photo of their requirements, but basically they are asking for either Apple ProRes 422HQ or Avid DNxHD.
    My project is UHD and I used proxies to edit. The timeline has been re-linked to the original files.
    The export seems to go fine, but the outputted files won't play, even though they are.mov. Quicktime opens, but I get a message saying "QuickTime Player can't open".  Also, after the export, if I try to do anything in MC, it gives me that 'bonk' sound effect like I'm trying to make it do something when it's busy. I have to force quit an re-launch to do anything.
    I have not exported in these formats in a long time and can't remember if this is how it's supposed to be or not. Seems like I should be able to play those files.
    Any help would be appreciated. I am on MC 2018.12.3
    iMac 27" Processor 3.8 GHz Intel Core i5 Memory 40 GB 2400 MHz DDR4 Graphics Radeon Pro 580 8GB Software Mac OS X Mojave 10.14.6 Media Composer 6... [view my complete system specs]
    Dwight Buhler   http://www.dwightbuhler.net/
  • Sun, Jun 16 2019 11:39 AM In reply to
    Re: ProRes HQ export question
    They offer you the possibility to submit a MOV or an MXF. The latter (Op1A MXF) is a very good option in MC. File->Export->AMA File Export.
    Other than that, doing a transcode or video mixdown of your sequence to either DNxHD or ProRes (if you're on Mac), then exporting the result Same As Source, that should give you the most reliable result for exporting a .mov in either of these codecs.
    Whatever you do, do NOT click 'Custom' settings in the QT export box to convert your sequence to APR or DNx. It uses the old slow, 32bit QT encoder, infamous for causing gamma shifts etc.
  • Sun, Jun 16 2019 10:07 PM In reply to
    • Dwight
    • Buhler
    • Posts 80
    • Points 1,060
    That worked perfect, thanks so much!. Did the video mixdown and outputted same as source.
    Thanks again!
