Latest post Sat, Jun 8 2019 10:09 AM by Joachim Claus. 13 replies.
Page 1 of 1 (14 items)
  • Tue, Jun 4 2019 10:52 AM
    • OWSucks
    • Joined on Tue, Dec 18 2012
    • Posts 30
    • Points 470
    What is the recommended workflow for creating h264 or x264 Blu Ray discs?
    Hi there,
    I'm having trouble figuring out the best workflow for producing a h264 or x264 blu ray disc.
    The previously advised workflow is QT mov or QT ref from Avid> Sorenson Squeeze to create blu ray files> Avid DVD to author blu ray disc.
    However, Avid DVD only supports MPEG-2 encoding for Blu Ray, and I've found the quality is not sufficient for my purposes. It's basically a really lossy crappy encoding that imo doesn't have enough advantage over DVD to be worth bothering with.
    Sorenson offers to create x264 or h264 renders for Blu Ray as an alternative to MPEG-2 encoding, but I'm struggling to find a software which can take the resulting .264 video file and .ac3 audio file and actually create a playable blu ray from it. Everything I've tried so far (including Avid DVD) just re-encodes the files into MPEG-2.
    What is the advised workflow for this? Ideally I need the ability to add a start menu as well before authoring.
    Custom Build PC | Media Composer v8.3.0 | Windows 7 Professional 64-bit | ASUS P8Z68-V PRO Gen3 | Intel i5 2500K OC@ 4.5GHz | Nvidia GTX 680 x2 SLI | Nvidia... [view my complete system specs]
  • Tue, Jun 4 2019 11:12 AM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 133
    • Points 1,520
    Re: What is the recommended workflow for creating h264 or x264 Blu Ray discs?
    Hi OWSucks,
    Sony Vegas DVD Architect is able to do what you want. You can download a trial version to check it out.
    https://www.vegascreativesoftware.com/us/dvd-architect/
    It was also possible with Encore DVD from Adobe. But I don't know if you still can rent Encore DVD at this time.
    Avid Media Composer 2018.12.3.51505.0 | Avid Symphony Option | Avid ScriptSync 2.0 | Avid PhraseFind 2.0 | Avid Pro Tools 11.3.1.370 | Avid Application... [view my complete system specs]
  • Tue, Jun 4 2019 11:14 AM In reply to
    My best guess would be Adobe Encore.
    For encoding, you could check out Pegasys TMPGEnc Video Mastering Works.
  • Tue, Jun 4 2019 11:15 AM In reply to
    CinéMatica:
    Hi OWSucks,
    This is probably a better answer!
  • Tue, Jun 4 2019 11:31 AM In reply to
    I'd dump Avid DVD. Plenty of low cost option that will do what you want.
    But MPEG2 should be fine as long as the datarates high enough. For BluRay I'd be looking at 35mbps or more.
  • Tue, Jun 4 2019 11:38 AM In reply to
    • OWSucks
    • Posts 30
    • Points 470
    The project is a stage produciton with a heavily spackled floor, and I'm finding on playback with MPEG-2 encoding that the spackling is creating all kinds of playback issues that are not present when using h264 or x264 encoding.
  • Tue, Jun 4 2019 12:34 PM In reply to
    • ZFigas
    • Joined on Tue, Jan 31 2006
    • Poland
    • Posts 103
    • Points 1,400
    TmpGenc doess not support MXF Op1.
    This encoder is OK but it is big drawback.
    Zb.
    HP Z820, 2xE5-2697, 64 GB RAM, Win 10 Pro, MC 2018.12.5, Nvidia Quadro RTX 4000, Boris Red 5.6, BCC 12.0.2, Saphire 11.0.2 Adobe CC. [view my complete system specs]
  • Tue, Jun 4 2019 12:56 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,398
    • Points 17,275
    Try the latest versioin of TMPGenc AUTHORING Works.
    It will build your BR complete with customizeable menus and now accepts mxf files.
    (If I were starting from scratch and didn't already have Encore sitting around, this is definitely the way I would go.)
  • Tue, Jun 4 2019 2:34 PM In reply to
    • ZFigas
    • Poland
    • Posts 103
    • Points 1,400
    Hello,
    I received the following answer from Support of Pegasys (7.05):
    At the moment MXF OP1A files with this codec Avid DNxHR and DNxHD
    are not supported.
    However, we will send this to the user's wish list.
    Greetings from Poland
    Zb.
  • Wed, Jun 5 2019 10:02 PM In reply to
    I would have said your best bet is using Adobe Encore and Media Encoder, but I'm not sure that you can get Encore now?
    1) Export File> Avid Media Processor > DNXHR HQ codec
    2) Import into Adobe Media Encoder > H264 Bluray preset
    4) Import into encore and create your bluray
  • Thu, Jun 6 2019 7:17 AM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 133
    • Points 1,520
    peacebreaker:
    Encore DVD was immediatly discontinued with the coming of CC in 2012. The latest version out there is CS6.
  • Thu, Jun 6 2019 9:17 AM In reply to
    • Julian
    • Joined on Thu, Jun 14 2018
    • South Africa
    • Posts 38
    • Points 430
    I use an old copy of Adobe Encore. I still have my cs6 licence.  Adobe does update it from time to time. It will encode and authour both blueray and dvd.  I will take a .mov from a fast export out of avid.
    This option depends if you can get an Encore licence though.
    Avid MC 2018; AMD Treadripper 1950x; Asus Zenith Extreem; msi gtx970; 32gig Gskill trident 3200mhz; EVO 960 250 sys drive; ibm 5014 raid0 with 3x3tb WD... [view my complete system specs]
  • Thu, Jun 6 2019 3:41 PM In reply to
    It used to be that you could go to "previous versions" for Premiere and download PremiereCS6, which includes Encore.  But it looks like CS doesn't show up anymore under "previous versions"...
  • Sat, Jun 8 2019 10:09 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 935
    • Points 11,950
    CinéMatica:
    Hi OWSucks,
    Just as additional information: DVD Architect is a superior software for DVD's. However it has some problems with BD's. When I load AVC-media files, it always stops loading, if the size of all loaded media files goes above 9 Gbyte. I do not know, whether this value is a fixed value, but after this amount of loaded media, I cannot load any additional file. DVD Architect stops in the middle of the import process.
    Joachim
    Joachim Claus
