Latest post Tue, May 21 2019 9:03 PM by dylanhowitt. 6 replies.
Page 1 of 1 (7 items)
  • Mon, May 20 2019 11:25 AM
    Issues consolidating audio for Protools
    Hi everyone,
    I'm havng trouble exporting audio from a sequence to give to a sound mixer for use in Protools.
    I'm on the latest MC Ultimate on a new iMac, using imported media shot on a C300. I've attached my export settings (also tried embedding in AAF).
    It works fine at first but crashes everytime at 'Gathering AAF dependencies'. When I look in the target folder the consolidated media is there but the sequence aaf file has nothing in it - eg is 0 bytes in size. Inside Avid the consolidated audio has been created in the bin.
    Any ideas what I'm doing wrong?
    Many thanks
    Dylan
  • Mon, May 20 2019 4:21 PM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 513
    • Points 6,380
    Re: Issues consolidating audio for Protools
    Just a guess - why are you converting the audio to OMF? Does it work if you don't?
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Mon, May 20 2019 5:37 PM In reply to
    • Posts 11,208
    • Points 231,130
    Hi Dylan
    I have seen this once before .....
    The last time I helped out with this issue, it seemed that the Projects the user had were getting very large and the MCState settings (you know those little folders in every project for each shared user station that's ever logged into the project) had gotten corrupt.
    They deleted them and restarted and relaunched and MC created new ones.
    The AAF export doesn't stall on "Gathering AAF Dependencies" or crash anymore for them.
    Worth a try.
    Marianna.
  • Mon, May 20 2019 7:40 PM In reply to
    Hi Marianna,
    Thanks for the suggestion, I tried it but still crashing unfortunately!
    Best wishes
    Dylan
  • Mon, May 20 2019 7:46 PM In reply to
    Hi Mikey,
    Thank-you - that seems to have done the trick!
    Best wishes
    Dylan
  • Tue, May 21 2019 4:31 PM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    Despite the converting - which you apparently didn't need - do you have group clips in your sequence? I know that error from versions where you have/had to commit multi-cam edits before sending them to AAF.
  • Tue, May 21 2019 9:03 PM In reply to
    Hi Cutyes,
    I don't in this edit, but yes that sounds like another potential pitfall to bear in mind!
    Dylan
