Latest post Tue, Apr 30 2019 9:48 PM by Sarita Siegel. 4 replies.
  • Thu, Apr 25 2019 11:52 AM
    • Sarita Siegel
    • Joined on Fri, Nov 10 2006
    • Bethnal Green, London
    • Posts 31
    • Points 360
    Using 4K in MC 2018.8
    HI,
    I am preparing to introduce quite a lot of 4k RED Scarlett footage into a long form documentary project that is 1080p/25. It will have a lot of archive and XF300 footage that is already transcoded at 185x. It is high res as I am firstly cutting a trailer to get more funding.
    But not knowing 4K RED files well, I cannot decide whether to transcode the RED material into a fairly good quality in REDCINE X PRO 50.5 to use for the trailer or download the RED AMA plug in as I will only need some for the trailer before figuring out a workflow for the long edit (at a less HD hungry offline resolution).
    Has anyone run into difficulties using the RED AMA plug in with MC 2018.8.0? Also what graphics card would be necessary if I go the AMA plug in route? I have a NVIDIA GeForce GTX 775M 2048 MB.
    cheers
    Sarita
    3.5 GHz Intel Core i7 16 GB 1600 MHz DDR3 512 SSD 36TB G-TECH G SPEED Studio (RAID 0) HD [view my complete system specs]
  • Thu, Apr 25 2019 3:19 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,694
    • Points 44,430
    Re: Using 4K in MC 2018.8
    Decoding RED is a CPU heavy task, so the GPU should not really be an issue.
    I would definitely take the route of AMA linking to the RED footage and transcoding in Avid to a good working codec.
    I especially would take this route depending on if / how you plan on taking the footage to a color session outside of Avid.  If you know that yet, we can offer some workflows.
    Jef
    Jef Huey
  • Thu, Apr 25 2019 6:04 PM In reply to
    I'd install the relevant Red AMA plugin.
    Link your AMA clips into a new bin.
    Transcode to you hgh quality DNx codec to match the other media. You may want to test what de-beyer setting works best.
    Its called Linked Source scaling/quality in the transcode window. With 4K sources for an HD output half best or half good is all you need. 1/4 1/8 or 1/16 will give a softer transcode but be faster to generate the media.
  • Tue, Apr 30 2019 9:42 PM In reply to
    • Sarita Siegel
    • Posts 31
    • Points 360
    HI Pat, thanks for this guidance.
    cheers
    Sarita
  • Tue, Apr 30 2019 9:48 PM In reply to
    • Sarita Siegel
    • Posts 31
    • Points 360
    HI,
    I will most likely do color on Da Vinci Resolve for the trailer.  Thanks for the suggestions.
    cheers
    sarita
