Latest post Wed, May 15 2019 7:41 AM by Benjamin Dodds. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • Tue, Apr 2 2019 5:41 PM
    Media Composer 2018.12.3 Now Available - 2 April 2019
     Media Composer 2018.12.3 – Launching 4.2.19 @ 12:00 Noon
    Avid is releasing Media Composer 2018.12.3 today, Tuesday, April 2nd, 2019 @ 12 PM EDT to address several issues.
    Location at Launch: Updates to Media Composer (subscription and perpetual), and Media Composer | Ultimate will be released at the same time, and will be made available from Avid Master Accounts (MyAvid), Avid Link, and the Avid Download Center (login and password required).
    What is fixed:  The issues Media Composer 2018.12.3 addresses are:
    - Bug Number: MCCET-2892. In some instances, playback would stop after adding an Audio Mark IN/OUT.
    - Bug Number: MCDEV-10686. Clicking on the checkbox for “Enable Mask Margin” or “Include Inactive Audio Tracks” in the AAF export dialog did not enable the options.
    - Bug Number: MCCET-2772. Clips may not have updated properly if you batch imported with Dynamic Relink enabled.
    - Bug Number: MCCET-2895. On some systems, the memory usage would increase until the editing application became sluggish.
    Limitations in this release:
    - Bug Number: MCDEV-8641. (AMD Graphics). Systems with AMD graphics cards might display tearing when performing Full Screen playback.
    Bug Number: MCDEV-9460. Windows 7 systems with Nvidia Maxwell or Nvidia Pascal cards might experience playback issues that could result in “Play Consumer timeout” errors. WorkaroundSelect “Disable GPU Effects” in the Render Settings dialog box.
    - Bug Number: MCDEV-9269. (Media Composer | Cloud) After performing a remote download operation on a sequence containing AVC-I 100 remote media, the downloaded media appears as XAVC-I 100. Workaround: Download the entire master clips.
    - Bug Number: MCDEV-9011. Intermittently, when working with the XDCAM Nablet Plug-in, you might see “Failed to get the sample position from the AMA Plug-in” errors if you have waveforms enabled in the Timeline.
    - Bug Number: COGS-2560. While working in the Script Window, text operations (cut/copy/paste/delete/editing) can only be done in edit mode. See “Editing a Script” in the Help.
    - Bug Number: MCDEV-5650. When working with Panasonic LongG media, you might receive an “SFPlayConsumer Timeout” error if audio waveforms are enabled. Workaround: Turn off audio waveforms.
    - Bug Number: MCDEV-5385. MultiCam editing with Panasonic LongG media is not supported
    with this release.
    ReadMe: The “ReadMe” document for this release of Media Composer 2018.12.3 has been uploaded to the Knowledge Base Media Composer 2018 Documentation Page at launch.
    Qualified OS: The following lists the qualified Operating Systems. Depending upon your hardware the qualified Operating Systems are:
    -  Windows v7 64-bit SP1(Professional) and Windows v8.1 (Professional and Enterprise), Windows v10 64-bit (Professional, Creators, and Enterprise).
    How to obtain Media Composer 2018.12.3 Update:  Listed below are the ways to obtain the new software.
    1. Customers who have already installed the 2018.12.x version of Media Composer will be notified of the availability of the upgrade to 2018.12.3 via Avid Link.
    2. Customers on current Update & Support plans can also download the Media Composer 2018.12.3 update either from their MyAvid Account or the Avid Download Center (login and password required).
    Media Composer 2019.7 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Wed, Apr 3 2019 9:26 AM In reply to
    • JRijken
    • Joined on Fri, Sep 21 2018
    • Belgium
    • Posts 17
    • Points 265
    Re: Media Composer 2018.12.3 Now Available - 2 April 2019
    Hi camoscato,
    Is this a general fix for 2018.12.2 ? Or are we no longer going by the monthly numbering? I.E 2019.4?
    Also, I've been wonderign if there is a fix in sight for the crashes on exit of the application?
    ( http://community.avid.com/forums/t/186441.aspx?PageIndex=5 )
    Thanks so much.
    HP z4, Avid MC 2018.10, 64GB RAM,NVidea Quadro M4000, Windows 10 pro, BM decklink extreme 4k 12G. [view my complete system specs]
  • Wed, Apr 3 2019 1:58 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,218
    • Points 14,595
    Per the readme, Qualified nVidia driver is now 411.95....but it's still 390.77 that comes in the Utilities folder ????
    Should one just go & download 411.95 from nvidia.com (bypassing OEM certified/recommended driver like 419.17 for DELL laptops) ?
    MC 2018.12.5 (Symphony option)/BCC2019 12.0.4/RED 5.6; BlackMagic Ultrastudio Mini Monitor (11.2); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz -... [view my complete system specs]
  • Wed, Apr 3 2019 2:26 PM In reply to
    Also when I search for  Nvidia Driver v411.95 I find that its not for Windows 10.
    Also there is no disclaimer like previous versions that say:
    "If you have a Quadro 4000 graphics card remain on the Nvidia v353.82 driver"
    Please clarify.
    David
    All PC Win 10 - 11 MC/Symphony Nitris DX 2018.12.5 - Interplay 3.6/90TB Mirrored Avid ISIS 5500 [view my complete system specs]
  • Wed, Apr 3 2019 3:34 PM In reply to
    • Arnoud
    • Joined on Sun, Dec 6 2015
    • Kwant
    • Posts 30
    • Points 345
    I can't tell you how happy I am with this update. The sluggishness became unbearable, because it was getting worse and worse until I did a restart, then everything was good again. I was already experimenting with all kinds of settings, and even uninstalled BM Desktop Video. Nothing worked, so this update is a godsend.
    Arnoud
    PC with Intel i9-7920X 2.90 Ghz processor, 64 Gb RAM, Nvidia Georce 2080ti GPU, running Windows 10 pro and iMac (Retina 5K, 27-inch, Late 2014) 4 GHz... [view my complete system specs]
  • Wed, Apr 3 2019 7:42 PM In reply to
    • bonang
    • Boston, MA
    • Posts 357
    • Points 4,445
    BenoitM:
    To BenoitM & david.feingold's point - the included driver should NAME the driver version (instead of just calling it "nVidiaDriverInstaller_win10.exe" etc.) Also not trusting the unnamed driver version, I quickly found the correct one online - here's the link for win 10:
    https://www.nvidia.com/Download/driverResults.aspx/140131/en-us
    It's confusing enough version-wise already without Avid compounding it by including unnamed driver versions.
    Avid MC 2019.6 with Symphony option | HP zbook 17" G3 / i7 6820HQ / 32GB RAM / 512GB SSD / WIN 10 PRO 64 / nVidia m3000m / BMD UltraStudio 4K [view my complete system specs]
    Keith
  • Thu, Apr 4 2019 6:11 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,610
    • Points 65,805
    As a workaround pretend to install the driver to find out the version: double click the nVidia installer, which will prompt You for a location to unpack named after the release version. I know it's clunky, but at least it works. Crossing fingers and going to try this release....
    peace luca
  • Thu, Apr 4 2019 7:07 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,218
    • Points 14,595
    luca.mg:
    That's where it says 390.77....
  • Sun, Apr 14 2019 6:08 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,112
    • Points 13,715
    I'm on an old Quadro K2000 graphics card - which driver should I use!?Geeked  Have always thought a $1000 GFX card is overkill for video editing as we arent doing CAD or 3D?
    Also is this new 'background save' a gag? My whole system freezes for 4" whilst it does a "background" save on a big project - and that's on a 2000Mbps write M2 SSD!  I'd rather the 'honesty' of the old 'chill, I'm saving' pop up!  Maybe its just my system :)
    Symphony 2018.12.3, Blackmagic Intensity Pro 11.1 (unsatisfactory in full res UHD though for client monitor), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K4200, Asus X99 Mobo, 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 @ 450Mbs
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Sun, Apr 14 2019 6:26 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,610
    • Points 65,805
    FWIW: I've always been on the lowest supported graphic card, so far so good. Not jumped on 2018.12.3 yet, but good old ordinary save is pretty fast, even on huge projects, I do not really feel like I need background save, especially since it seems that it still needs to exit the beta stage.
    peace luca
  • Mon, Apr 15 2019 7:39 AM In reply to
    • Arnoud
    • Kwant
    • Posts 30
    • Points 345
    Background save IMO is one of the best new features of Avid Media Composer, and it has been long overdue. Autosave was one of my main frustrations, because it always seemed to kick in when I was about to do something creative. And clients sometimes don't understand why I freeze when we are in the middle of something. On my system (which is quite new and fast) autosave works as it is supposed to. I expect Media Composer 2019 to have an even more sophisticated auto-save mechanism, where each edit decision is saved rightaway so zero loss in in case of a crash.
    I think this 2018.12.3 release is the best release Avid has ever turned out. It is fast and stable: a real workhorse. Avid seems to renumber the december release so as to avoid having to call it Avid Media Composer 2019, which is the name for the new revamped Media Composer. This latest december release will be around a long time until people dare to start using this new and no doubt buggy new product.
    JMO
    Arnoud
  • Mon, Apr 15 2019 7:56 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,610
    • Points 65,805
    peace luca
  • Wed, Apr 24 2019 4:27 PM In reply to
    Wierd timeline issue.  On Video timeline layers we are getting 2 or 3 duplicate layers.  IE, 3 V10s and 3 V11s and 3 V12s.  Odd.  W10x64
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440 PC's on W7 x64. 2 x Mac, 4 x PT 2019.5 HDX, S6 , X-MON, all on PCs. NEXIS E4 & ISIS 5000 X 2. [view my complete system specs]
  • Wed, Apr 24 2019 5:13 PM In reply to
    Does anyone know if Titler+ bugs have been ironed out in this newest version?  I am trying to use Titler+ with 2018.12.2 right now on a system with RTX2020 graphics card and I'm having all sorts of weird font issues.  Typing with basic font is sluggish.  Some fonts just don't look like they're supposed to.  Even the effect editor has bugs: changing "size" parameter affects "width percentage" parameter and the fonts don't scale without getting squished.  It's basically useless to me.
    Avid Media Composer 2018.12 Intel i9 9900K desktop Windows 10 Pro 64GB RAM BlackMagic Design Decklink Mini Monitor Nvidia RTX2080 display card [view my complete system specs]
    Jason Spencer, Director/DP/Editor digitallunchbox.com
  • Thu, Apr 25 2019 6:59 PM In reply to
    • Posts 10,606
    • Points 223,185
    Hey there
    A bunch of them were tweaked in 2018.12.3... and I suspect there will be more done in the May release.
    I woudl definately upgrade to 2018.12.3 if you can
