Latest post Thu, Aug 29 2019 1:37 PM by ck123. 13 replies.
Page 1 of 1 (14 items)
  • Thu, Mar 28 2019 12:35 PM
    • mkj
    • Sweden
    • Posts 454
    • Points 5,995
    A bug? Some users cant click/scroll/close open bins
    Its like that the bin you see, is not there, so when you try to move it nothing happens.
    On one client this was resolved by upgrading to 2018.11, but now I have 2 clients that had that version, and I upgraded to 2018.12.1, but the problem is still there...
    anyonye who have had this problem?
    HW: z240, 4.2 ghz, 32 gb RAM Intel HD graphics
  • Fri, Mar 29 2019 9:25 AM In reply to
    • mkj
    • Sweden
    • Posts 454
    • Points 5,995
    Re: A bug? Some users cant click/scroll/close open bins
    NO ONE else have this problem?
    maybe poor description
    but just a minute ago one user opened a bin and couldnt mark a clip or close it. The only way to close the bin is to right click on it in "Bins"-window..
    And it does not happen to all bins, its random
  • Sat, Apr 6 2019 7:03 PM In reply to
    You are not alone with that problem. We have the same bug with bin. We tested trial versions of new Avid MC to future upgrade from v.8.5 and had the same problem on 3 PCs. Problem bins were first created by new project. In some of cases solution is double clicking on upper edge of that bin window. Double click resizes bin to one row dimension and returns ability to normal work with it.
    11 PCs HP Z6, AVID MC 2018.12.10, MC 2019.7 [view my complete system specs]
  • Mon, Apr 8 2019 7:38 AM In reply to
    • Revenger
    • Joined on Wed, May 11 2011
    • Estonia
    • Posts 90
    • Points 1,145
    +1
    MC 2018.12
    MC 2019.12; HP Z800; Windows 10 Pro 64-bit; Dual Quad-Core Intel(R) Xeon(R) X5570 @ 2.93GHz; 24GB (6 x 4GB) DDR3 1333 ECC RAM; NVIDIA Quadro FX 4800 (driver... [view my complete system specs]
  • Mon, Apr 8 2019 8:09 AM In reply to
    • mkj
    • Sweden
    • Posts 454
    • Points 5,995
    it seems like 2018.12.3 solved this problem!
  • Thu, Aug 1 2019 7:31 AM In reply to
    • MylesOSS
    • Joined on Fri, Jul 13 2018
    • Posts 13
    • Points 165
    I can confirm that this problem still exists in 2018.12.6. It's proven to be present across multiple HP Z4 computers in our facility. In this case it was a locked bin that was in use by another machine. You can't move the bin, click to close or double click on clips to load into source monitor. Nothing can be selected. If a bin is sitting behind the problem bin, the click actions are registered there instead (in my case clip text was selected in the bin behind).
    Double clicking the bar at the top will automatically resize the bin to make it larger and the problem goes away, but then it returns not long after. It only seems to affect specific bins. Copying all the clips into a new bin solves the problem until it comes back with a different bin further down the line as the project is worked on and grows larger.
    Anyone been able to get to the source of the problem (specific setting etc..)?
    It seems to be an issue with the bin being corrupt somehow and so far the only work around is to resize the bin or make a new one.
  • Thu, Aug 1 2019 1:32 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 157
    • Points 1,990
    Yes. Have this problem as well. Even posted a video of it. We're running 2018.11 with Windows 10 1803, We're starting to roll out Windows 10 1809 to see if that brings any improvement. My personal theory is it's a problem with Media Composer's interpretation of the windowing metrics used in Windows 10. Probably related to how Avid coded the support for display scaling.
    http://community.avid.com/forums/t/197067.aspx
    HP zBook 17 G3, z220, HP z240, HP z420, HP z440, HP z840, HP Z4 G4, Dell Precision 3430, Dell Precision 7810, Apple iMac i5 27-Inch (5K, Late 2015). 16GB... [view my complete system specs]
  • Fri, Aug 2 2019 1:07 PM In reply to
    • dbiok
    • Joined on Fri, Mar 19 2010
    • Germany
    • Posts 49
    • Points 585
    We also have this "bug". Not every user has this problem. Same machine, smae project, different user, for user A everthing is ok, user B has this bug and the other day vice versa. Trashed all settings again, created new ones and even then, it is totally random when it appears.
    If you have the bug, close the BIN via project window (rklick close) and then open it again. You will see the BIN in the upper left corner. But it is very small. It seems that it happens not on all newly created BINs. I can not track it down, cause of it's randomness.
    so long & thx
    dbiok
    [3x MediaComposer 2018.12.6 @ NitrisDX || HP Z800 Workstation (Dual XEON X5570) || Win10 64Bit] - [1x Symphony 2018.4 @ NitrisDX || HP Z800 Workstation... [view my complete system specs]
  • Wed, Aug 28 2019 2:14 PM In reply to
    • bobbybz
    • Joined on Mon, Oct 26 2015
    • Posts 39
    • Points 515
    I, too, have this issue. I'm on a Z440 and running Windows 7 and MC 2018.12.3.
    HP Z440, Intel Xeon E5-1650v3@ 3.5GHz, 32GB RAM (2x16), Windows 7Pro 64bit - Service Pack 1, Nvidia Quadro K2200 (driver v390.77), Blackmagic Decklink... [view my complete system specs]
  • Wed, Aug 28 2019 2:31 PM In reply to
    • mkj
    • Sweden
    • Posts 454
    • Points 5,995
    solved with 2018.12.7 (with hp z2)
  • Wed, Aug 28 2019 2:37 PM In reply to
    • bobbybz
    • Posts 39
    • Points 515
    Thanks for confirming. I will speak with our post team about having us all upgrade.
  • Wed, Aug 28 2019 2:53 PM In reply to
    • ck123
    • PA
    • Posts 157
    • Points 1,990
    Is this "solved" per Avid or you just haven't seen the problem repeat after installing 2019.7? With our 2018.11 we don't see the problem every single day. It can be days or even weeks before the problem re-appears. And, if it is fixed per Avid in 2019.7 when will it be fixed in the 2018.12.x branch?
  • Wed, Aug 28 2019 2:56 PM In reply to
    • bobbybz
    • Posts 39
    • Points 515
    I can't answer your first question, but according to mkj's post it WAS solved in the 2018 branch:   2018.12.7.
  • Thu, Aug 29 2019 1:37 PM In reply to
    • ck123
    • PA
    • Posts 157
    • Points 1,990
    This version duplicity looniness is going to get us all one day. Stick out tongue
    Read through the 2018.12.7 read me and don't see any mention of a bug that describes this problem. Would be good to hear from Avid on it. Fixed "true" or fixed "anecdotally."
