Latest post Mon, Jul 13 2020 5:38 PM by Brian Berdan, ACE. 16 replies.
  • Wed, Mar 6 2019 9:14 AM
    • JamesG
    • Posts 225
    • Points 3,040
    Project opening stuck on Color Correction Presets
    Help! My project won't finish opening - it's stuck on Loading "Color Correction Presets"
    Need to solve this urgently... Many thanks for any ideas.
    Media Composer 2018.11 on 12 Core 2x2.66 GHz Mac Pro Cheesegrater 16GB RAM, OSX 10.11.6, AJA IO Xpress [view my complete system specs]
  • Wed, Mar 6 2019 9:20 AM In reply to
    • JamesG
    • Posts 225
    • Points 3,040
    Re: Project opening stuck on Color Correction Presets
    It's not user or project specific...
  • Wed, Mar 6 2019 9:28 AM In reply to
    So a fresh user setting and a new project still leave it stuck?
    I'd make sure the current project is backed up and uninstall and re-install MC.
  • Wed, Mar 6 2019 9:53 AM In reply to
    • JamesG
    • Posts 225
    • Points 3,040
    I've just done a fresh install and it's still getting stuck... It was fine yesterday
  • Wed, Mar 6 2019 9:58 AM In reply to
    • JamesG
    • Posts 225
    • Points 3,040
    Need urgent help with this - anybody?
  • Wed, Mar 6 2019 10:00 AM In reply to
    • JamesG
    • Posts 225
    • Points 3,040
    Apparently there shold be a color presets files here:
    The Colour Correction Presets should be installed in Applications/Avid Media Composer/ Supporting Files/Avid_EffectsPresets/Color Correction Presets.aep
    But I don't have that, even with a fresh install...
  • Wed, Mar 6 2019 10:02 AM In reply to
    • radrattus
    • Joined on Wed, May 9 2018
    • Posts 24
    • Points 300
    Can you try opening the project with all bins closed?
    http://community.avid.com/forums/t/90344.aspx
  • Wed, Mar 6 2019 10:16 AM In reply to
    • JamesG
    • Posts 225
    • Points 3,040
    I've done fresh MC install, new project, new user, open project with no bins = still stuck trying to load CC Presets...
  • Wed, Mar 6 2019 10:20 AM In reply to
    I'm on a PC but I don't have that path. My color correction Presets.aep is at:
    C:\Users\Public\Documents\Avid Media Composer\Avid_EffectsPresets
    But if you did an uninstall (and then delete all the Avid media composer folders to clear any preferences) and re-installed anything missing should be replaced.
  • Wed, Mar 6 2019 10:39 AM In reply to
    • JamesG
    • Posts 225
    • Points 3,040
    So switching off my AJA IO Express box makes the problem go away...
    But obvs also makes the client monitor and audio go away...
  • Wed, Mar 6 2019 10:52 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    Hi James,
    did you leave it being stuck for a while? I once had that with a project whenever I had to switch between different 2018.x versions. After waiting a minute or two the - seemingly frozen - MC proceeded. Once I had done that, MC opened the project in regular time until I had to switch versions again.
  • Wed, Mar 6 2019 11:07 AM In reply to
    • JamesG
    • Posts 225
    • Points 3,040
    I've left it for a few minutes.
    The fact that losing the AJA box fixes it means there must be some new clash - makes no sense as it was working fine..
  • Wed, Mar 6 2019 11:51 AM In reply to
    I'd try uninstalling the AJA drivers. This should allow MC to launch in software mode.
    Then try re-installing the AJA drivers.
  • Wed, Mar 6 2019 10:00 PM In reply to
    • JamesG
    • Posts 225
    • Points 3,040
    I've discovered that the problem is caused by the Mini-converter Analog-SDI (which I use to be able to record guide VO).
    If I switch it off all works fine.
    I haven't connected it since upgrading to MC2018.11
    Could the MC upgrade require an AJA driver upgrade, eveh though I didn't upgrade the OS?  I am on 12.3.0 firmware which is a little old but works fine without the converter connected.
  • Thu, Mar 7 2019 3:39 PM In reply to
    • DonE
    • Joined on Tue, Aug 18 2009
    • California, USA
    • Posts 118
    • Points 1,380
    I wonder if switching on / off the mini-conv is just like connecting / disconnecting any SDI signal to the IO Express.
    This thread by jef looks a lot like what you are seeing.
    http://community.avid.com/forums/p/186378/867258.aspx#867258
    1x AMC/Sy 8.6.5-Win10 Pro 64 1809-HP z800-dual 6core-24GB-Quadro FX 4800-Nitris DX QT775 NV341.74** 3x AMC/Sy 8.6.5-Win10 Pro 64 1809-HP xw8600-8GB-Quadro... [view my complete system specs]
