Latest post Mon, Feb 25 2019 11:06 PM by Randall L. Rike. 0 replies.
Page 1 of 1 (1 items)
  • Mon, Feb 25 2019 11:06 PM
    Avid NEXIS | FS 2019.2 - Now Available
    Great news!   Avid is pleased to announce the release of Avid NEXIS | FS 2019.2.
    This release introduces:
    -  MacOS 10.14 Mojave support
                -  MacOS 10.14 Mojave Avid NEXIS Client Support
                - The Avid NEXIS 2019.2 client on macOS Mojave can connect to Avid NEXIS (2018.11 or 2019.2
                  recommended) or Avid ISIS 4.7.5 and higher.
    -  Support for Avid NEXIS Data Migration Utility for macOS systems.
    -  Data Migration Utility is now supported for Windows and Mac.
    -  Support for 2 Peta Bytes in a single Storage Group on Avid NEXIS | Cloud Storage system.
    How to obtain Avid NEXIS | FS 2019.2:  Avid NEXIS | FS 2019.2 is now available to qualifying customers with support plans via MyAvid accounts. The Avid NEXIS Client v19.2 is also available on the Download Center.
    ReadMe: For full details see the 2019.2 ReadMe that is be posted on the Avid NEXIS Documentation page.
    Recommended and Supported Versions
    Product
    Version
    Description
    Avid NEXIS
    2019.2
    Recommended Release for all Avid NEXIS systems;
    - Support for macOS 10.14 Mojave Avid NEXIS Client
    - Support for Avid NEXIS Data Migration Utility on macOS
    - Up to 2PB in Avid NEXIS | Cloud Storage System
    Avid NEXIS
    2018.11
    Recommended Minimum Release for all Avid NEXIS systems
    - Introducing NEXIS SNMP Support:
    - Introducing CentOS 7.5 support for the Avid NEXIS Client
    - Multi-Select in HTML-5 Management Console capabilities
    Avid NEXIS
    2018.4.0
    Required Minimum Version for all Avid NEXIS
    This release resolves an issue that prevented correct reporting of Meta Data SSD failures.
    Note: All customers running earlier Avid NEXIS | FS versions MUST run the Avid NEXIS SSD Monitoring Utility daily. This utility is available in the MyAvid account of all Avid NEXIS Customers
    Avid NEXIS 7.3 to 2018.3 does not correctly report failure of the shared metadata SSDs in Avid NEXIS Engines (including PRO 20TB & 40TB) and SDA. Please update to Avid NEXIS 2018.4 or higher and use the Avid NEXIS SSD Monitoring Utility every day to check status of the shared SSDs.
    Avid NEXIS | PRO
    Firmware r4.1.16d
    Required for all Avid NEXIS | PRO storage
    All Avid NEXIS customers are strongly advised to upgrade from Avid NEXIS v5.x or v6.x to at least v2018.4
    Avid ISIS
    V4.7.9
    Minimum Recommended for all Avid ISIS Systems.
    Includes multiple stability enhancements.
    (wwld)
