Latest post Mon, Jul 22 2019 1:16 PM by Jon Sheldon. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Feb 5 2019 3:38 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,254
    • Points 15,000
    Multicam live cut
    Often, when I try to live cut to a camera angle while playing a sequence in mcam mode, playback stops as soon as I select a cam angle (with mouse or num key).
    This is not consistent, and I haven't been able to determine what could cause this.
    Am I overlooking something ? Could it be a performance issue (system doesn't seem to be stressed) ? A GPU driver issue (I'm using a different nVidia driver 'cause Avid provided driver (390.77) doesn't want to install on my DELL) ?
    MC 2018.12.10 (+Symphony)/BCC2019 12.5.2/RED 5.6; BlackMagic Ultrastudio Mini Monitor+Recorder (11.4.1); DELL Precision 5530 - Intel Core i7-8850H 2.6... [view my complete system specs]
  • Fri, Feb 8 2019 8:18 AM In reply to
    Re: Multicam live cut
    Try totaly delete avid user and create new one. It helps me with this issue. Avid mc 2018.12.1
  • Fri, Feb 15 2019 3:21 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,254
    • Points 15,000
    In case someone would have the same issue, here is the solution/workaround (whether this will permamently fix the issue needs to be confirmed), discovered almost by chance with the help of Avid support:
    In normal mode, change the Timeline Video Quality to "best performance" and go back to mCam again: cut to camera angle no longer interrupts playback; from there changes to any Video Quality no longer breaks the mCam live playback...TBC?
  • Fri, Feb 15 2019 5:35 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,744
    • Points 44,900
    Interesting.  My memory tells me in versions before the 2081.x, Best Performance was automatically selected when in Multicam.
    That could be a false memory though.
    Jef
    Jef Huey
  • Sat, Feb 16 2019 5:31 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,254
    • Points 15,000
    Ahem, in fact, the "workaround" I described fixed the issue only for a while.
    It is now back, and changing Video Quality doesn't help anymore...I have reactivated my support case....
  • Wed, Feb 20 2019 12:55 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,254
    • Points 15,000
    Support could repro...the cause is mixed rate group (a 50p and several 50i/25p clips in one group, multicam edit in a 50i T/L). Logged and Engineering is investigating.
  • Fri, Feb 22 2019 7:50 PM In reply to
    BenoitM:
    Personally I never use mouse or num key for switching cameras. I am always assigning the cams from the command pallette to the keyboard (F-buttons). In this way play does not stop when changing cameras.
    HTH
    pixel
    iMac Mid 2016 / High Sierra 10.13.6 / 32 GB RAM / MCA 2019.12 / MojoDX / Adobe CC 2018 / MBPro Mid 2015 / High Sierra 10.13.6 / 16 GB RAM / MC 2019.12... [view my complete system specs]
    What is editing? It´s the process of transforming a collection of badly focussed or horribly framed shots containing reversed screen directions, flare and dirt into a smooth visual statement of the script... ... for which the director takes the credit!
  • Mon, Jul 1 2019 3:03 PM In reply to
    • Jon Sheldon
    • Joined on Tue, Jan 15 2013
    • London, UK
    • Posts 7
    • Points 65
    Any update on this?
    I have the same problem. The workaround didn't work for me, it makes no difference if use the mapped M1-4 keys or click with the mouse. Everytime I make a multicam edit playback stops.
    Please help.
  • Tue, Jul 2 2019 11:55 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    I'm not seeing this. What type of media are you using and what are your project settings? Could it be that certain types of linked media or frame size/rate affect multicam in this way?
    Steve
    www.nelliedogstudios.com
  • Tue, Jul 2 2019 1:06 PM In reply to
    • Jon Sheldon
    • London, UK
    • Posts 7
    • Points 65
    This hasn't been a problem for us until now, possibly introduced with the last update
    Media is 1920x1080p50 ProRes from Blackmagic Hyperdeck Studio Pro recorders
    Linked to a 1080p25 project
    MC 2018.12.3 running on Windows 10 HP Z8 PC.
  • Mon, Jul 22 2019 12:43 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,254
    • Points 15,000
    The repro I mentioned earlier is fixed (I haven't tested yet, though):
    Media Composer 2018.12.4 [...] contains the fix for MCCET-2859 - Switching camera angles in Multicam stopped playback if the group contained mixed frame rates.
    http://resources.avid.com/SupportFiles/attach/README_Avid_Editor_v18.12.4.pdf
  • Mon, Jul 22 2019 1:16 PM In reply to
    • Jon Sheldon
    • London, UK
    • Posts 7
    • Points 65
    Thank you for the prompt. I will give it a try and see what happens. Wondering if our issue is slightly different in that playback stops even when frame rates are matched.
