Latest post Fri, Jan 11 2019 12:04 AM by Twosheds. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jan 10 2019 5:34 AM
    • Twosheds
    • Joined on Wed, Mar 15 2006
    • Melbourne, Australia
    • Posts 91
    • Points 995
    MC 2018.12 ProRes export problems
    I have just done a clean install of MacOSX 10.14.2 Mojave onto a 2015 27" iMac. I installed Avid Media Composer 2018.12 and during testing found I was unable to export an Apple ProRes Quicktime.
    Previously we did have Apple Compressor, DVD Studio Pro installed which meant the Apple Pro quicktime components were installed.
    Do I need to install the old software or should I be able to export a ProRes Quicktime directly from MC2018.12
    thanks
    Media Composer Ultimate 2019.6 and 20.4.0 Mac OSX 10.14.6 and 10.15.4 DNxIO and DNxIQ iMac 27" Late 2013 i7 16GB, iMac 27" 2019 i9 64GB MacPro... [view my complete system specs]
    Filed under: , ,
  • Thu, Jan 10 2019 9:33 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    Re: MC 2018.12 ProRes export problems
    If you don't mind to install Compressor then that will bring back the codec(s). I think DVD Studio does too, but I haven't installed that software in a long time. When you own at least one of the pro apps - as you do - there are other ways to install the codecs only, without installing one of the apps. (For example google "install prores without proapps")
    There might be better answers though. I always install Compressor on any new setup, not (only) for the codecs but rather for its actual purpose. So I never went into that question any further.
  • Thu, Jan 10 2019 1:42 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 174
    • Points 2,030
    Hi Twosheds,
    No, you do not have to install the old software.
    Yes, there is a way to do this without installing the old NLE's. Take a look at the link below!
    Installing the Apple Pro Video formats without Final Cut Pro or ProApps
    Enjoy!
    Friendly greetings,
    Ivan
    (Avid 1) HP Z840 | 2x 18 Core Intel Xeon E5-2699v3 / 2.3GHz 35MB | 128GB PC4-17000P 2133MHz / 8x 16GB DDR4 | NVIDIA Quadro P4000 / 8GB GDDR5 / 4x DP 5K... [view my complete system specs]
  • Thu, Jan 10 2019 3:05 PM In reply to
    FYI - I think this technically violates Apple EULA. You need a licensed ProApp in your computer to officially activate ProRes encode.
    A better non-EULA-violating workflow is to do a mixdown in Avid and export as Same As Source.
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Thu, Jan 10 2019 5:11 PM In reply to
    Without the ProRes codec installed, it will not be an option as a Custom QuickTime export. But as Dom says, you can do the mixdown and export Same as Source.
    You should be able to open ProRes movies in QuickTime X.
  • Thu, Jan 10 2019 7:06 PM In reply to
    • janusz
    • Paris
    • Posts 394
    • Points 4,580
    Another factor (undocumented as far as I am aware, but confirmed by tests I performed a few years ago) is that the use of a Custom... QT export (i.e. by configuring the Quicktime-provided dialog box that appears) is *always* an 8-bit export regardless of the source codec or the chosen destination codec.  I doubt this has changed since I performed these tests.
    As a result, with sequences relinked to 10 bit AMA sources, or sequences containing 175X/185X/220X media, a mixdown to Prores followed by a same-as-source export gives a higher quality result (the native Avid codecs are used, and Quicktime is not involved).  Furthermore, the colorimetry can be more accurate - the levels options do not influence a SAS Prores export (they modify metadata on DNx exports that affect the decode levels with the quicktime codec).  I always recommend this workflow, and avoid Custom...  in nearly all cases.
    Janusz
    MC 2018.12 / OS 10.12.6 + others elsewhere [view my complete system specs]
  • Fri, Jan 11 2019 12:04 AM In reply to
    • Twosheds
    • Posts 91
    • Points 995
    Yeah, I thought so. I think I'll just install Apple Compressor and then delete the actual Compressor app. We have Adobe Encoder as well.
