Latest post Tue, Aug 6 2019 8:31 AM by JayMoss. 28 replies.
Page 2 of 2 (29 items) < Previous 1 2
  • Wed, May 15 2019 1:03 AM In reply to
    • Kyler
    • Joined on Wed, Feb 26 2014
    • Boudreau
    • Posts 84
    • Points 950
    Re: Sorenson Squeeze Update | Avid 1.7.19
    I've been using Apple Compressor for a long time now. Been really happy with the results and the price tag. Use it for both HD and 4K workflows.
    Macbook Pro / G-Raid Shuttle [view my complete system specs]
    kyler boudreau | kylerboudreau.com
  • Sat, May 25 2019 8:32 PM In reply to
    • hartfilms
    • Joined on Wed, Nov 16 2005
    • Los Angeles
    • Posts 152
    • Points 1,570
    Since upgrading to 2018.12.3, my Squeeze 11 won't open as a standalone. It keeps asking me to activate media composer or buy the program. maybe I need to reinstall. Are there folders I should remove manually after uninstalling?
    MC 2018.12.3 - HP Z440: Intel Xeon E5-1650v3 3.50GHz 15MB 2133 6C CPU; G8U34AV 32GB DDR4-2133 (4x8GB) RegRAM; NVIDIA Quadro K2200 4GB DL-DVI(I)+2xDP 1st... [view my complete system specs]
  • Sun, May 26 2019 9:13 AM In reply to
    • Enrico
    • Joined on Thu, Apr 29 2010
    • Italy - Grosseto
    • Posts 62
    • Points 780
    I have sorenson squeeze as part of media composer (I don't remember, probably got with 5.0 or earlier). now, it asks for activation, and I cannot activate due to being discontinued (or sorenson in bancrupt, you chose).
    is there a way to activate it anyway?
    AMD phenom2 x4 965 asrock 880g extreme3 4x2gb ddr3 Win seven ultimate [view my complete system specs]
  • Sun, May 26 2019 10:54 AM In reply to
    From the email that Sorensen sent out Aug 15, 2018:
    Squeeze Desktop We have developed a new version of Squeeze that will not communicate with any registration server and will allow you to upgrade to Squeeze 11.1 Pro using the serial number for any previous version of Squeeze. There is no cost for this upgrade. However, we cannot guarantee that the software will continue to work past September 1, 2018. We recommend that you seek alternate encoding solutions immediately. Here are the latest Squeeze Desktop 11.1 installation files. Please download these installers immediately as they may be taken down or moved after September 1, 2018.
    Mac: https://sorenson_media_support.s3.amazonaws.com/SqueezeDesktop/SqueezeEOL/11.1.0.204/Mac/Signed/Squeeze_Mac_Installer.zip Windows: https://sorenson_media_support.s3.amazonaws.com/SqueezeDesktop/SqueezeEOL/11.1.0.203/Windows/Signed/SqueezeWebInstall.exe
    Your current installation of Squeeze may still work when the registration server goes down on September 1st. However, you will need to use the new Squeeze 11 installer if you decide to reinstall Squeeze for any reason. If you have trouble installing Squeeze, please try uninstalling and reinstalling using the thorough uninstall method described at the end of this email.
    Squeeze Thorough Uninstall Instructions
    This will completely remove Squeeze Desktop from your machine
    Win 8/Win7/WinVista
    1. Uninstall Squeeze by going to Start > Control Panel > Programs and Features > Sorenson Squeeze (all versions) > Change/Remove > Uninstall.
    2. Uninstall FFDShow by going to Start > Control Panel > Programs and Features > ffdshow (all versions) > Change/Remove > Uninstall
    3. Note: FFDShow is no longer installed automatically as of Squeeze 8.Please continue to the next step.
    4. Delete the Squeeze folder located here:
    5. C:\Users\[your name]\AppData\Roaming\SorensonMedia\
    6. If you can't see this folder you may need change your folder options by going to Tools > View > and check the box next to Show Hidden Files and Folders. Note: This is your custom settings folder so if you have any custom presets you may want to export them from Squeeze and save them elsewhere or make a copy of this folder and place it in a different location.
    7. Reboot your PC (if possible).
    Win XP
    1. Uninstall Squeeze by going to Start > Control Panel > Add or Remove Programs > Sorenson Squeeze (all versions) > Change/Remove > Uninstall.
    2. Uninstall FFDShow by going to Start > Control Panel > Add or Remove programs > ffdshow (all versions) > Change/Remove > Uninstall   *Note: Skip this step if using Squeeze 8 or higher. FFDShow is no longer installed automatically.
    3. Delete the Squeeze folder located here:
    4. C:\Documents and Settings\[your name]\Application Data\SorensonMedia
    5. If you can't see this folder you may need change your folder options by going to Tools > View > and check the box next to Show Hidden Files and Folders. Note: This is your custom settings folder so if you have any custom presets you may want to export them from Squeeze and save them elsewhere or make a copy of this folder and place it in a different location.
    6. Reboot your PC (if possible).
    Mac OS X
    1. Open your Applications folder and drag the Squeeze folder to the trash.
    2. Open Finder and go to Macintosh HD (system volume) /Library/Preferences/
    3. Delete the .plist file "com.SorensonMedia.Squeeze 6.plist" (If there are more than one .plist file with SorensonMedia or Squeeze in the name, delete them all.)
    4. Open Finder and go to Macintosh HD/Users/[your user name]/Library/Preferences/ and delete the .plist file "com.SorensonMedia.Squeeze 6.plist" If there are more than one .plist file with SorensonMedia or Squeeze in the name, delete them all. *Note to OSX 10.7-10.9 usersTo view the Macintosh HD folder you will need reveal the Library folder by following the steps below*
    5.  Delete the "SorensonMedia" folder *Note: This is your custom settings folder so if you have any custom presets you may want to export them from Squeeze and save them elsewhere or make a copy of this folder and place it in a different location.
    *OS 10.7, 10.8, and 10.9 users
    The Library folder in your user home directory is hidden by default. You will need to make it visible by using one of these methods:
    Method #1
    • Open Finder and go to your user' home folder (Macintosh HD > Users > [your user name])
    • Click on the "Go" menu at the top of the screen
    • Hold down the ALT key to reveal the Library folder
    • Click on the Library folder in the Go menu and now perform step #5 above.
    Method #2
    • Open Terminal in your Utilities folder in Applications.
    • Type the following into Terminal or cut and paste:  chden ~/Library/
    • chflags nohidden ~/Library/
    • Now your Library folder will be visible and now perform step #5 above.
  • Sun, May 26 2019 12:10 PM In reply to
    • Enrico
    • Italy - Grosseto
    • Posts 62
    • Points 780
    thank you, trying it now!
  • Tue, Jul 2 2019 1:35 PM In reply to
    Hi, I missed the opportunity to upgrade to Squeeze 11 - didn't know about it. And due to PC breakdown recentlly I lost all sw and had to reinstall everything. I have always used Squeeeze to encode QT reference files from Avid MC. My old, wellfunctioning Squeeze has a license key but no serial number, and I can't reinstall it! Does enyone has a "free" Squezzez 11 that can be transferred to another computer?
    Extremely grateful for help!
  • Tue, Jul 2 2019 5:13 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 189
    • Points 2,205
    Hi Suzanne,
    From which version of Squeeze is your licence key coming from?
    Ivan
    (Avid 1) HP Z840 | 2x 18 Core Intel Xeon E5-2699v3 / 2.3GHz 35MB | 128GB PC4-17000P 2133MHz / 8x 16GB DDR4 | NVIDIA Quadro P4000 / 8GB GDDR5 / 4x DP 5K... [view my complete system specs]
  • Tue, Jul 2 2019 5:39 PM In reply to
    Originally I don't remeber, but my last version was 6.5...
  • Mon, Aug 5 2019 7:21 PM In reply to
    • JayMoss
    • Joined on Fri, Feb 22 2013
    • Posts 19
    • Points 215
    Curent fastest workaround I have found is to export AAFs, drop those into Premiere and encode them through AME!
    Its rediculous that this is necissariy in 2019 but it seems to be the quickest way of rendering out, and means that Avid isn't tied up exporting.
    If anyone has found a better solution i'd be glad to hear it!
  • Mon, Aug 5 2019 7:52 PM In reply to
    JayMoss:
    For what issue exactly?
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Mon, Aug 5 2019 9:21 PM In reply to
    • JayMoss
    • Posts 19
    • Points 215
    This is my workaround for exporting quickly from Avid now that quicktime Reference files are no longer supported by Media Encoder and Avid no longer comes with Squeeze. I would like to be able to batch export sequences without tying up my Avid and AAF > Premiere > Media Encoder is the fastest route I have come up with. It seems like there must be a better way, but I haven't seen one mentioned...
  • Mon, Aug 5 2019 9:50 PM In reply to
    I think someone mentioned that TMPGEnc still supports QT Ref.
    http://tmpgenc.pegasys-inc.com/en/product/tvmw7_spec.html
  • Tue, Aug 6 2019 1:19 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,747
    • Points 61,915
    Yes it does.
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, Aug 6 2019 8:31 AM In reply to
    • JayMoss
    • Posts 19
    • Points 215
    Must have missed that, will check it out. Thanks
