Latest post Fri, Apr 12 2019 5:41 PM by Lukas Boeck. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Nov 22 2018 9:59 AM
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    What's the difference of media processor vs op1a export
    Newb question here.
    Im editing everything in uhd dnxhr these days.
    I edit music videos that are all shot in slomo... The only way for me to multicam these slomo performances is to speed each one up, stack each clip on a sync timeline, then burn in timecode.
    Before I would mixdown every clip. And add that to the group, but I wanted more of a batch process of every take/layer.
    Now im subclipping every layer and doing a batch export of everything then consolidating those exports.
    The Main Question:
    Im exporting to dnxhr_lb..
    But I noticed op1a seems a little quicker, or there were less things going on than media processesor.
    So whats the difference between media processesor and op1a for dnxhr exports?
    Does it do something different with audio?
    thanks!
    Added feature request (since its related, i know theres a forum for that).  It would be cool if I could just highlight a bunch of sequences and it would just do a mixdown with audio of it.  Instead of me having to export these mixed down mxf's then linking and consolidating so I can group these originally slomo clips.    --- And yes I always make sure I backup my mixdowns since theyre not timecoded.
    Ill add a screen shot later once this export of all my takes is done.
    w10, mc 2020.4, diy x299 7940x [view my complete system specs]
  • Wed, Nov 28 2018 9:01 PM In reply to
    Re: What's the difference of media processor vs op1a export
    You are exporting DNxHR in low bitrate.
    This is your choice.
    But how are you doing it?
    SAS (Same as source) or by Avid Processor?
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Fri, Nov 30 2018 5:22 PM In reply to
    An example is that if you are working with AVC-100 Intra you can't export it as OP1a.
    But you can by Avid Processor.
    Desktop PC
  • Fri, Nov 30 2018 11:27 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 590
    • Points 6,980
    yeah, but exporting XDCAM from Avid Processor results in an OP1a file that broadcasters will accept.
    honestly, i think there is no difference.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Fri, Nov 30 2018 11:31 PM In reply to
    How is there no difference?
    You can export AVC-Intra only by Avid Media Processor and SAS.
    Not by OP1a.
    Desktop PC
  • Fri, Nov 30 2018 11:37 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 590
    • Points 6,980
    yes, but Avid Media Processor still creates OP1a files.
    Under the hood both options might be identcal or near identical.
    The devs would know, as far as i cant tell only the codec selcetion is different.
  • Fri, Apr 12 2019 8:27 AM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    If the clips on my timeline are rendered as dnxhr_lb but I export at dnxhr_hqx
    Is media processor exporting at a higher quality that what my clips were rendered at?
    thx
  • Fri, Apr 12 2019 8:32 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 590
    • Points 6,980
    cls105:
    No, the file exported file might be bigger in HQX, but unless you relink the timeline to original footage it'll end up with DNxHR LB quality.
  • Fri, Apr 12 2019 9:36 AM In reply to
    The export process maybe the same (for now) but the development is going into the Avid Media Processor route so its likely that will see improvements over the traditional export process.
  • Fri, Apr 12 2019 5:35 PM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    I could have been more clear with my last question.
    The clips on my timeline are HQX but I usually render to uhd lb for snappier and lighter editing.
    So if I export to hqx with media processor, it it using those lb renders, or is it re-processing to hqx.
    Thank you
  • Fri, Apr 12 2019 5:41 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 590
    • Points 6,980
    You mean, you do your effects rendering to LB.
    My absolute bet would be, that you loose the quality.
    You can clear the renders for a product, export and find out if reder time increases.
    You could render to an ssd, i'll eat my hat if you loose snappyness in HQX then.
