Latest post Thu, Sep 12 2019 4:31 PM by jenzer. 7 replies.
  • Tue, Nov 13 2018 7:59 PM
    • rami562
    • Joined on Tue, Nov 13 2018
    • Posts 4
    • Points 70
    DPX Not Linking into Avid
    Long time reader, first time poster. I'm on a PC running MC 8.9.2 and I'm trying to link to a DPX file but I keep getting the error: "The file I:\VXF_Incoming\01_310_v01\01_310_v01\A017C006_180930_R178\A017C006_180930_R178_00000.dpx cannot be linked. Do you want to import it?
    My drive is a Mac drive that I'm accessing through Mac Drive, but even if I move the DPX to a Windows drive, I still can't link to it. My project is the same resolution and settings as the DPX file. I can see it fine is Resolve too. Any ideas why Avid can't see it?
  • Wed, Nov 14 2018 7:13 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,742
    • Points 47,935
      Moderator: MCA Mac
    Re: DPX Not Linking into Avid
    Not every media type can be linked, and that includes DPX. I'm presuming that you're trying to digest the entire image file sequence. This must be imported, which will transcode it to a video file for use with MC.
    Dave S.
  • Wed, Nov 14 2018 11:23 PM In reply to
    • rami562
    • Posts 4
    • Points 70
    Avid can link to DPX, I do it all the time. I just can't figure out why it doesn't want to link to some but will to others. Maybe because it's 12-bit? That wouldn't make sense though since we can export 12-bit DPX, but who knows.
  • Thu, Nov 15 2018 6:10 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,669
    • Points 66,515
    Try shortening the path, not sure this is the issue, but if the linking footage belongs to folders with a shorter path You may give this a try.
    Symphony 20.04, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Thu, Nov 15 2018 6:55 PM In reply to
    • rami562
    • Posts 4
    • Points 70
    Great suggestion but no luck unfortuantely!
  • Thu, Nov 15 2018 9:03 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,742
    • Points 47,935
      Moderator: MCA Mac
    I'm so used to having to import image sequences, I did not realize DPX could be linked. I think it's safe to presume you've renamed everything according to the spec. at http://avid.force.com/pkb/articles/en_US/How_To/DPX-file-Naming-convention-for-AMA-linking. Are you trying to link to a single file (which doesn't work), or to the folder and the first file is causing issues?
    Dave S.
  • Fri, Nov 16 2018 12:31 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,741
    • Points 61,845
    I didn't realize it either. I just tried exporting my timeline as DPX and then linking to the result - works very nicely! Sorry I don't have anything to add to this conversation.
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Sep 12 2019 4:31 PM In reply to
    • jenzer
    • Joined on Tue, Oct 23 2018
    • Posts 1
    • Points 5
    The issue with Avid and DPX files seems to be the image packing setting.
    IF you are on MC version 2018.10 and up frame packing must be set to 0 which is packed to 32 bit words. if you set to 1 or filled to 32 bit words, MC will throw AMA error.
    FYI 16bit DPX do not require filling so this issue will be alleviated.
    -jason
