Latest post Sat, Nov 17 2018 9:38 PM by mPepe. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Oct 26 2018 5:09 PM
    • kd-53
    • Joined on Wed, Apr 28 2010
    • Duesseldorf, Germany
    • Posts 32
    • Points 405
    MC 2018.10 crashes when exporting quicktime reference
    today I switched from MC 2018.8 to MC 2018.10. Everything worked fine until I tried to export the final sequence to a qicktime reference. MC finished with an exeption. It is a UHD project 25p, video and audio are mixdowns. I tried it with other files and other project settings (1080 25i). Same result. I closed MC and rebooted the system. Same result.
    So I switched back to MC 2018.8. Now the export works fine with the same sequence. This seems to be a bug. Does anyone have the same problem? In the near future I will stay on MC 2018.8.
    Best regards
    Kl
    aus-Dieter
    Mobo: MSI MPG-Z390 Gaming Edge AC, i9-9900K, 32GB Ram, Win 10 Prof 64, GeForce GTX 2060 Super with 8 GB Ram, BM Intensity Pro 4K, MC 2019.12.1, BCC11,... [view my complete system specs]
  • Sat, Oct 27 2018 8:31 AM In reply to
    • kd-53
    • Posts 32
    • Points 405
    Re: MC 2018.10 crashes when exporting quicktime reference
    this is the error message I received:
  • Sat, Oct 27 2018 9:14 AM In reply to
    • gswilson
    • Joined on Thu, Feb 4 2010
    • Belfast, Ireland - now, Frankfurt am Main, Germany
    • Posts 339
    • Points 4,455
    I'm seeing the same exception error message when trying to export a QT Ref. and I filled out the message panel and sent it to Avid.
    I can export a QT Ref for Squeeze without any issues when I select Sorenson Squeeze from the export options.
    Gerry
    MC 2019.12, Win 10 Pro(1909), Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 1080Ti GPU(Studio Driver 442.19),Samsung 850 Pro... [view my complete system specs]
  • Sat, Oct 27 2018 9:20 AM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 153
    • Points 1,865
    I have the same experience with 2018.10.
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Sat, Oct 27 2018 12:37 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,741
    • Points 61,845
    Yes - this is a bug. Switch your audio output to WAVE format in the QT Ref settings. Very odd that this got past SQA but at least there is a workaround.
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Oct 27 2018 2:18 PM In reply to
    • gswilson
    • Posts 339
    • Points 4,455
    Thanks for the workaround Steve. Really wierd that something like this could slip through testing.
    Gerry
  • Sat, Nov 17 2018 9:38 PM In reply to
    • mPepe
    • Joined on Sat, Dec 2 2017
    • Posts 1
    • Points 5
    I'm experiencing the same problem. I get an "Alert" that says: "Segmentation fault" in thread "MainThread", at address   0x0
    Then MC crashes. It creates a .mov file that is not supported in Squeeze.
    And yes, as suggested elsewhere changing the audio output to Wave did the trick. The .mov file then imported into Squeeze.
