Latest post Sat, Oct 13 2018 8:25 PM by mcabery. 10 replies.
Page 1 of 1 (11 items)
  • Wed, Oct 10 2018 7:18 PM
    • mcabery
    • Posts 78
    • Points 995
    Waveform live update
    My aplogies if this has been covered.  I keep seeing that we are supposed to have live updates in the scopes, but I am not seeing this.  I have checked the box for live updates in the settings but the scopes don't update until the video stops.  Thoughts?
    i7 Broadwell 6800K on an Asus X99A-II, 6 2TB Seagate drives in RAID 5, Windows 10, MXO2 Mini Max and the latest version of Avid [view my complete system specs]
  • Wed, Oct 10 2018 8:15 PM In reply to
    Re: Waveform live update
    What version are you using?
  • Wed, Oct 10 2018 8:40 PM In reply to
    • mcabery
    • Posts 78
    • Points 995
    2018.9
    Sorry, it's been so long since I have posted on the forum I forgot how to do it properly!Smile
  • Thu, Oct 11 2018 4:22 AM In reply to
    I just tried it on the system listed in my specs, and in color correction mode the scopes updated in realtime. Just to double-check, are you in color correction mode when you're looking at the scopes? (I realized this is a pretty basic question, but I don't want to overlook anything.)
  • Thu, Oct 11 2018 10:14 PM In reply to
    • mcabery
    • Posts 78
    • Points 995
    No problem, best to start with the basics! Yes, I'm in color correction mode. Perhaps I'm misunderstanding the feature also, what I'm expecting is that as the video plays the scopes play along too  Or is it just that they update while making changes in the color correction?
  • Fri, Oct 12 2018 5:27 AM In reply to
    mcabery:
    That's what happens on my system.
    What video card are you running?
  • Fri, Oct 12 2018 8:10 AM In reply to
    On my system I get live updates while making adjustments and live update if I scrub. But when I hit play the WFM freezes and only updates when I stop.
  • Fri, Oct 12 2018 3:55 PM In reply to
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 262
    • Points 3,480
    your color-correction-mode-three-way-displays must be set up only to show waveforms(any), not the "Next" clip, nor the "Previous" clip. Only waveforms in the side monitors and the current clip in the middle.  MC plays Waveforms in realtime only in thes display setup. This was covered in documentation somewhere....
    my zoo: NEXIS Pro 40 tb sw v18.6.1; MBPro_late_2013 15'' i7 16GBram OSX 10.12.6 MC 2018.12 BMD US monitor (or AJA io XT ), EXT thunderbolt NvidiaGPU... [view my complete system specs]
    DJFio[DB]
  • Fri, Oct 12 2018 4:57 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,527
    • Points 45,365
    DJFio[DB] is correct. Both left and right displays must be set to show waveforms (or histogram, quad-display, etc.) for real-time to work. They can also be set to Entire Sequence or to Empty for real-time display to work. Note that you don't have to use the center display. As long as one of the displays is set to Current (or Entire Sequence), you can put the monitors in any of the others (so you could set it up like histogram/waveform/current) it it will still work.
    Dave S.
  • Fri, Oct 12 2018 5:02 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 590
    • Points 6,690
    YesIdeaYes
    mc 2018.12.1 with symphony - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i... [view my complete system specs]
  • Sat, Oct 13 2018 8:25 PM In reply to
    • mcabery
    • Posts 78
    • Points 995
    Ah ha!  That was the problem, I had the left screen of the three set to previous, when I put the vectorscope over there and a WFM on the right side it works...! Hooray and thanks for your input!
