Latest post Mon, Oct 15 2018 5:41 PM by Marianna. 15 replies.
  • Wed, Oct 10 2018 9:24 AM
    Cannot Disable GPU effects on Avid 8.6.3
    Hello there,
    I recently got a render glitch with my Avid MC 8.6.3 which I think is caused by a glitch withing the rendering. IN FACT, I got a screen with horizontal lines, and at a time also a totally green screen, which is quite annoying.
    Now, I read that a possible solution for this is to DISABLE THE GPU EFFECTS on the render settings. The problem is that when I open the render settings menu, the DISABLE GPU effect is selected and I am not able to UNCHECK IT.
    Any solution for this?
    Thanks so much.
    Chiara
  • Wed, Oct 10 2018 12:59 PM In reply to
    • Posts 9,809
    • Points 212,995
    Re: Cannot Disable GPU effects on Avid 8.6.3
    Go to Settings > Render Settings. Use the checkbox to manually Disable GPU Effects
    Exit Media Composer after changing the setting.
    Restart MC
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Wed, Oct 10 2018 1:20 PM In reply to
    Hi MARIANNA,
    Thank you for your quick response.
    My problem is that on the render settings, the DISABLE GPU box is greyed, so I am not able to modify that in any way. I found that on Windows machines, you can manually delete the file ​C:\Program Files\Avid\Avid Media Composer\DisableGPU.txt. BUT I am on a MAC, so I don't find that.
    Any help? THANKS SO MUCH
  • Wed, Oct 10 2018 1:25 PM In reply to
    • Posts 9,809
    • Points 212,995
    Me Bad!  Mac forum doh!
    1. Go to the  Apple menu and choose “System Preferences” and then go to “Energy” control panel.
    2. Uncheck the box next to “Automatic graphics switching”
  • Wed, Oct 10 2018 1:35 PM In reply to
    Ok done that, open Avid MC and the box is still checked and greyed out. And the render glitch (horizontal bars) still there :(
  • Wed, Oct 10 2018 2:33 PM In reply to
    What GFX card are you using?
  • Wed, Oct 10 2018 2:39 PM In reply to
    AMD Radeon R9 M370X 2 GB
    Intel Iris Pro 1536 MB
  • Wed, Oct 10 2018 2:40 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 300
    • Points 3,460
    if you go into video playback/video quality settings in the timeline and switch openGL to software mode, does the render setting become available?
    Dave
    "A very big network"
  • Wed, Oct 10 2018 2:54 PM In reply to
    JUst tried that, switched to Open GL and no, the render settings are still NOT available.
  • Thu, Oct 11 2018 11:41 AM In reply to
    Any other advice guys? Maybe try to disistall and re-install the software? By the way is this issue solved in the Avid MC 9?
  • Thu, Oct 11 2018 1:54 PM In reply to
    Have you tried a different Avid user? That might be a first step.
    But if that doesn't work, then I would look at uninstall/reinstall.
    There is no MC 9. Avid is now releasing monthly updates and they are numbered by year/month. 2018.9 is the current version and 2018.10 will be released shortly.
    I am not seeing issues with the current release, but I'm also not using your GFX card.
  • Thu, Oct 11 2018 2:36 PM In reply to
    • Posts 9,809
    • Points 212,995
    Kevin Klimek:
    100% agree with Kevin!
    marianna
  • Thu, Oct 11 2018 4:28 PM In reply to
    Thanks Kevin, i changed the user but the problem is still there.
    I now want to buy a monthly subscription to get to the most updated version of Avid, and uninstall my own permanent avid.
    Marianna, shall I uninstall my Avid and pay for the monthly subscription, or the uninstall is not necessary since the updated version will automatically replace the older version?
    Thanks.
  • Thu, Oct 11 2018 4:36 PM In reply to
    Once your MyAvid account reflects the new subscription, I would strongly reccommed you uninstall your current version, then use Application Manager to install the latest version or download it from the Avid Download Center and do it manually.
  • Mon, Oct 15 2018 5:32 PM In reply to
    Hi guys,
    Just to let you know that upgrading to the latest Avid has solved the issue. I now have unchecked the box of disable GPU effects an dthe green screen/horizontal lines are gone!
    Thank you so much for your help!
    Best,
    Chiara
