Latest post Fri, Sep 21 2018 11:20 AM by Pat Horridge. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Sep 21 2018 3:47 AM
    • Julia B
    • Joined on Fri, Sep 21 2018
    • Posts 1
    • Points 15
    AAF issues
    Hello
    I am currently working in a project with 4k and 2 k footage at 23.97 frame rate. My post colourist is working with DaVinci resolve and I am trying to get an AAF file to hime. When he imports, half the files show offline. We both have the raw data laid out in identical file strucutre.That is issue one.
    Number two...I am trying to export a WAVE file and keep getting the error Exception:AAudioBufferDescriptionHM::AcquireStorage cannot acquire less than 1 smple. What does that mean? How do I fix it.Your wisdom and guidance on these matters are GREATLY appreciated.
    Thank you
  • Fri, Sep 21 2018 11:20 AM In reply to
    Re: AAF issues
    Ask the colourist to find the first offline clip in the imported sequence. Check that clip is available and online in his media pool.
    Compare the clip info for the media pool version with whats shown in the sequence.
    Either the clip isn't in the media pool or it is but there is a metadata mismatch. When you know which thing is wrong you can then decided how that happened and what the fix is.
    re the Wav have you tried a small test first with a single clip? or break the sequence into 2 and try each half.
