Latest post Tue, Oct 9 2018 11:33 PM by BobRusso. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Aug 28 2018 7:33 AM
    • IT Admin
    • Joined on Tue, Jun 12 2018
    • Posts 3
    • Points 55
    Avid Nexis Client Manager 18.6.1.14 - No network interface found
    We have new laptops and can't connect to our Nexis Pro while on wireless. If we click on Network interface settings we a message saying "There were no network interfaces found". If I connect a cable it works ok.
    Anyone else that has seen this? Can't find any info on it.
    AvidNexis  18.4.0.5
    Intel(R) Dual Band Wireless-AC 8265
    Nexis Client Manager 18.6.1.14 Br Mattias
  • Tue, Aug 28 2018 5:09 PM In reply to
    Re: Avid Nexis Client Manager 18.6.1.14 - No network interface found
    I assume you have wired connection to the Nexis network?
    if yes and the wireless is interfering, check to make sure that the wired port is not being disabled automatically. Modern Windows will often disable wired ports when wireless is active.
  • Tue, Aug 28 2018 7:49 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 139
    • Points 1,750
    Are you trying to access Nexis over wireless?
    HP zBook 17 G3, z220, HP z240, HP z420, HP z440, HP z840, HP Z4 G4, Dell Precision 3430, Dell Precision 7810, Apple iMac i5 27-Inch (5K, Late 2015). 16GB... [view my complete system specs]
  • Mon, Sep 3 2018 6:49 AM In reply to
    • IT Admin
    • Posts 3
    • Points 55
    Yes, trying to access Nexis over wireless. Not to work via but to be able to easy copy files to a laptop.
    Br
    Mattias
  • Tue, Sep 18 2018 2:43 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,845
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    IT Admin:
    This isn't supported and won't work. The NEXIS client filters out the WiFi connection.
  • Tue, Oct 9 2018 8:46 PM In reply to
    Bob,
    You are very clear on the limitations of the Nexis Client. But I want make sure my users understand, the Nexis (18.5.0.3 is our version) Client does not support wireless useage, even through a VPN? The client only works hard wired through the network to mount the volumes?
    Thanks for your help.
    Brandon Carpenter
    Big Smile
  • Tue, Oct 9 2018 11:33 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,845
    It doesn't matter if the computer is in the building connected to the WiFi on the same network as the NEXIS; there's too much latency in a WiFi connection, it won't work and is specifically filtered out. You can setup a File Gateway if you'd like to use a workspace via WiFi.
