Latest post Wed, Aug 1 2018 8:04 PM by apmende. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jun 28 2018 6:56 PM
    • apmende
    • Posts 38
    • Points 620
    GROUPED CLIPS - Not showing Duration
    Avid Media 6.5.4
    OSX 10.7.5
    I have a Multi grouped clip that when I mark an "In" to "Out" on any channel, it will not give me a duration.  It is not until I cut that group into a sequence that I can actually see a duration.  Is this a glitch?  Am I doing something wrong?
    Filed under: ,
  • Thu, Jun 28 2018 10:09 PM In reply to
    Re: GROUPED CLIPS - Not showing Duration
    Where are you hoping to see the duration? In the bin, or in the Center Duration window? For the latter, you need to have an active track selected in the ( top of the two) timecode windows above the source monitor.
  • Thu, Jun 28 2018 10:51 PM In reply to
    • apmende
    • Posts 38
    • Points 620
    The center duration Video in-between the source and record monitors.  I have an in and out marked and I know the grouped clip is more than an hour and it's telling me -13:24 (13 mins 24 secs).
  • Fri, Jun 29 2018 5:53 AM In reply to
    So, which timecode is selected in the top TC window above the Source Monitor? Because that is where Center Duration takes its directions from.
  • Fri, Jun 29 2018 8:55 PM In reply to
    • apmende
    • Posts 38
    • Points 620
    They are all on V1 TC in the above display windown but I also put it to AUX TC because the AE's group with that and still nothing.
  • Fri, Jun 29 2018 11:19 PM In reply to
    • NinaLu
    • Joined on Fri, Jul 12 2013
    • Posts 28
    • Points 320
    My guess would be that your V1 track is shorter than others either at the head or tail (or both) so it can't read timecode at one end or both ends due to it being non-existant.
    Can you toggle to a track that spans the entirety of the clip and see if that shows a duration? Usually one of the audio tracks is long enough as they tend to run longer on both ends than picture.
  • Wed, Aug 1 2018 8:04 PM In reply to
    • apmende
    • Posts 38
    • Points 620
    I did that and it still wasn't showing the duration.
    Thanks!
