Latest post Thu, Jul 5 2018 3:56 PM by Kevin Klimek. 4 replies.
  • Tue, Jun 26 2018 7:33 PM
    • NinaLu
    • Joined on Fri, Jul 12 2013
    • Posts 28
    • Points 320
    Reverse Match Frame Not Working
    On my system, when matching from the edit to source it gets the wrong frame, around a second off, and if I do it again right away without moving to another frame, it picks a different frame rather than give me the error beep. Then if I keep doing it it jumps back and forth between the two incorrect frames it has decided it should match to.
    It is not working at all now to match from source to record. It used to do the incorrect match. Not sure why that changed.
    I'm using autosynced clips. If I match back to the master it still doesn't work from source to record but does match correctly from record to source, but that doesn't help at all, since I'm going between two versions of an edit.
    This is a HUGE issue for editing if you are used to it, particularly when working with a director/prducer in the room.
    This worked correctly in 8.9.1, can't speak to the versions in between. Is it known which version introduced this bug?
    This is a fresh install of 8.9.4, with newly created user settings, OS X El Capitan.
    What's the outlook for a patch to fix this in 8.9.4? I found a thread in the PC forum from January with no solution.
    Thanks!
  • Fri, Jun 29 2018 9:50 PM In reply to
    • NinaLu
    • Posts 28
    • Points 320
    Re: Reverse Match Frame Not Working
    Any thoughts or solutions on this?
  • Mon, Jul 2 2018 2:15 PM In reply to
    I can't test this as I am using the more current versions of MC, which doesn't have this issue.
    There won't be plans to patch old software...the new framework is to keep current with the releases as they come.
  • Wed, Jul 4 2018 1:02 AM In reply to
    • NinaLu
    • Posts 28
    • Points 320
    Thanks for your reply.
    So those of us whose support/updates end at 8.9.4 are left with a broken product? That doesn't seem right.
  • Thu, Jul 5 2018 3:56 PM In reply to
    Well, to be fair, I don't know if any piece of software that doesn't have SOME bugs in it. It's the nature of the beast these days.
    If you choose not to stay current, you may have to live with the status of the software when you end your support. Avid isn't the only one who does it...Adobe, Microsoft, Apple...everyone has to draw the line somewhere. Avid is trying to speed up development and improvements to their software and one way to do that is to focus on a single base of code and not support multiple versions at the same time.
    If this bug is a major one for you, you may need to a) reconsider not upgrading to the current version) or b) roll back to a previous version where it wasn't an issue. At some point the OS or a camera format you need to use may force your hand anyway.
    Sorry it's not a great answer, but it is the world we live in these days.
