Latest post Wed, Jun 27 2018 2:48 AM by persyst. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Jun 24 2018 6:32 PM
    • persyst
    • Joined on Tue, May 27 2014
    • Posts 161
    • Points 2,080
    How to add 'Mute Clip' and 'Unmute Clip' to Keyboard?
    Could anyone please tell me how to, if it's possible, add the Mute Clip and Unmute Clip commands to the Keyboard in MC8.4?
    Thanks!
    Media Composer 2019.6 Pro Tools 2019.6 Mac Pro 2013, MacOS High Sierra 10.13.6 • 2.7GHz 12-core with 30MB of L3 cache • 64GB (4x16GB) of 1866MHz DDR3... [view my complete system specs]
  • Mon, Jun 25 2018 2:14 PM In reply to
    Re: How to add 'Mute Clip' and 'Unmute Clip' to Keyboard?
    You can use "Menu to Button Reassignment" in the Command Palette.
    The Mute/Unmute Clip commands are under the Timeline menu.
  • Mon, Jun 25 2018 3:17 PM In reply to
    • persyst
    • Posts 161
    • Points 2,080
    I'll give this a try, but this would only give me the option to have a clickable button for the commands, correct?
    How would I then add the Mute/Unmute commands to a keyboard button? I don't see Mute/Unmute listed anywhere on the command palette commands.
    Thanks.
  • Mon, Jun 25 2018 3:35 PM In reply to
    You can map any menu command to any keyboard button OR any button within the interface.
    1. Open your Keyboard Setting.
    2. Open the Command Palette and make sure "Menu to Button Reassignment" is active.
    3. The cursor, when hovering over the keyboard setting, will change to a little menu icon. Click the key you want to assign the function to.
    4. Go to Timeline > Mute Clips. When you release the button, you'll see MC assigned to that button.
    5. Repeat for Unmute. You'll see UC assigned to that button.
  • Mon, Jun 25 2018 3:51 PM In reply to
    • persyst
    • Posts 161
    • Points 2,080
    Ah perfect! Thank you!
  • Wed, Jun 27 2018 2:43 AM In reply to
    • NinaLu
    • Joined on Fri, Jul 12 2013
    • Posts 28
    • Points 320
    To add to that... if you want to use the same button for both mute and unmute, you can hold "shift" to add the second one to the same button and then also use shift+button to use that second command.
    I do a lot of opposite commands on my kb using the shift, so all my marks turn to unmark if I use shift with them. It's a very handy way to add a lot more to the kb in a logical fashion.
  • Wed, Jun 27 2018 2:48 AM In reply to
    • persyst
    • Posts 161
    • Points 2,080
    Great suggestion. Thank you!
