Latest post Mon, Jun 18 2018 7:08 PM by LDV20. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Jun 12 2018 4:22 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 171
    • Points 2,045
    Driver Version for BM Intensity Pro 4K needed
    I know several people are using this card succesfully in MC 2018.5 - wondering what driver version is working well?
    Much appreciated help
    thank you
    Symphony 2018.3 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media, BM Intensity... [view my complete system specs]
  • Tue, Jun 12 2018 8:23 PM In reply to
    • fropdaddy
    • Posts 17
    • Points 205
    Re: Driver Version for BM Intensity Pro 4K needed
    I'm using driver 10.9.12.0 dated 3/22/2018 and have had no issues.
  • Wed, Jun 13 2018 7:21 AM In reply to
    • kd-53
    • Joined on Wed, Apr 28 2010
    • Duesseldorf, Germany
    • Posts 23
    • Points 310
    I am using the same driver also without issues.
    Mobo: Asus Z270-A, i7-7700K, 32GB Ram, Win 10 Prof 64, GeForce GTX 1060 with 6 GB Ram, BM Intensity Pro 4K, MC 2018.8, BCC11, 2 x 24" monitors, Sony... [view my complete system specs]
  • Wed, Jun 13 2018 2:56 PM In reply to
    • LDV20
    • Posts 171
    • Points 2,045
    Thank you - will install that driver
  • Wed, Jun 13 2018 2:57 PM In reply to
    • LDV20
    • Posts 171
    • Points 2,045
    Also KD - what slot did you put it in since we have almost the same MB
    thank you
  • Wed, Jun 13 2018 3:07 PM In reply to
    • kd-53
    • Posts 23
    • Points 310
    the card is in the slot PCIEX16_2.
    Best regards
    Klaus-Dieter
  • Thu, Jun 14 2018 9:00 PM In reply to
    • wkumingo
    • Chicago
    • Posts 172
    • Points 2,380
    Is anyone using the Intensity Pro 4K for HDMI monitoring to a client monitor? I think there's a problem with the output levels being too low. I just noticed it yesterday.
    Looking at SMPTE bars on the Color Correction Y-Waveform shows black correctly at 7.5 IRE, but when monitoring the video on an external scope it shiftes down to 0, thereby cutting off the "blacker-than-black" 3.5 IRE strip and making accurate brightness adjustment on the monitor a guessing game.
    You can also more or less prove this without an external scope by cranking up the brightness on the external monitor. The 3.5 IRE strip is not there since it's been clipped off on output.
    I tried drivers 10.9.12, 10.10, and 10.11 (released today) but none have fixed the issue. I have not tried an Avid re-install back to 2018.4 or 2018.3 yet.
    I'm curious if anyone else can replicate this issue before I completely tear my system apart looking for a fix.
    Self-built -- Always current MC version with AJA KONA 1 card OS: Windows 10 Pro 64-bit, System: X99 Motherboard, Core i7-6850K, GTX 1080 Ti, 32GB RAM... [view my complete system specs]
  • Thu, Jun 14 2018 9:14 PM In reply to
    • LDV20
    • Posts 171
    • Points 2,045
    Waiting for the Intensity to be delievered -  looks like I will install friday.  I will take a look at this and let you know
    thank you for the heads up
  • Thu, Jun 14 2018 9:17 PM In reply to
    • LDV20
    • Posts 171
    • Points 2,045
    come to think of it - I think for digital - the black does sit at 0-   For  Analogue I think it is 7.5 - but I am not sure if i am correct on this.  I will look into the proper specs for digital
  • Fri, Jun 15 2018 8:51 PM In reply to
    • wkumingo
    • Chicago
    • Posts 172
    • Points 2,380
    Let me know if you can see the 3.5 IRE black bar on your external monitor after you get your Intensity Pro 4K set up. I really think this is a bug and I will probably start a new thread about it, especially if you have the same problem too.
    Thanks!
  • Sat, Jun 16 2018 1:40 PM In reply to
    • LDV20
    • Posts 171
    • Points 2,045
    I got the BM set up in the computer - but did not hook my monitor to test out the video - audio is fine so I assume the instlall is ok.    Using a the old Matrox before and and a sony LMD (somethiong) as monitor I went crazy trying to get the color bars accurate.  Could not get bars reading proplerly.    I finally returnd the monitor - a fully calibarated broadcast monitor to me is the only way to really see all those nunances in color bars.  Now that is my  opinion other people may have better luck.  I am looking at buying a flanders down the road.
    So what Monitor are you using to evaulate the signal?
    The only decent monitor I have is the Oydssey 7Q+ whihc is close but not really calibrated - it does what I need even in color correction for WEB videos.   Any project with a decent budget I will send my work out to a colorist.
    I will set up the Oydssey  later on and report back.
    BTW if you or anyone else has recomendation on a Monitor either be a actaul consumer TV or Computer monitor that is decent let me know (but computes monitors are RGB so not sure if that is good?) -  my sights are set on flanders sometine in the future.
    thank you
  • Mon, Jun 18 2018 4:38 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,096
    • Points 13,465
    Consumer TV screens often delay the video so they are always out of sync...  So annoying!
    Symphony 2018.12.3, Blackmagic Intensity Pro 11.1 (unsatisfactory in full res UHD though for client monitor), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K2000 (rolled back 388.16 driver to see if matches old but adequate card better), Asus X99 Mobo, 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 @ 450Mbs
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Mon, Jun 18 2018 7:08 PM In reply to
    • LDV20
    • Posts 171
    • Points 2,045
    I am using the external audio outputs into monitor speakers.   I have not tried my samsung consumer Tv - but it used to be in sync.  What monitor are you using
    thanks
