Latest post Thu, May 17 2018 4:32 PM by jef. 1 replies.
Page 1 of 1 (2 items)
  • Thu, May 17 2018 3:45 PM
    • be
    • Joined on Tue, Jan 5 2016
    • Posts 4
    • Points 60
    Safe Color Limiter as Checkmark, when exporting
    It would be a nice feature, if you are exporting for an xdcam disk, or other exports, with an option to limit the colors for tv-norms (with Presets). So the editor is safe, when he has to deliver to a tv-station.
  • Thu, May 17 2018 4:32 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,666
    • Points 44,105
    Re: Safe Color Limiter as Checkmark, when exporting
    Not sure of your workflow, but I do this as a matter of course.
    Put Safe Color Limter on the top most track.  Select the sequence and Export.  At least when doing an OP1a export, the render to the file takes into consideration the Safe Color Limiter.
    The advantage to this versus having an automatic action (which is which is what I think you are asking for) is that I can be selective as to what parts of the sequence are limited.  I do not want to limit Color bars for example.
    Jef
    Jef Huey
