Latest post Tue, May 22 2018 9:04 AM by luca.mg. 11 replies.
Page 1 of 1 (12 items)
  • Wed, May 16 2018 6:46 AM
    Media Composer crashes after loading project when external harddrive is connected
    Hello. I just downloaded and installed Media Composer First. I have all my clips and media on an external harddrive but for some reason MC crashes after loading or creating a project. When I disconnect my harddrive it works though. Would be great to be able to have it connected so that I can bring in media from it. This works with any other software without any problems.
    I'm on windows 10.
    Windows 10 Home 64-bit. Intel core i7-4710HQ CPU @2.50ghz 2.50ghz 16gb RAM Intel HD Graphics 4600 + Nvidia Geforce GTX 850M [view my complete system specs]
  • Wed, May 16 2018 1:37 PM In reply to
    • Posts 10,384
    • Points 220,480
    Re: Media Composer crashes after loading project when external harddrive is connected
    Emil
    Do you get an error message of any kind?
    Win 10 Professional and Enterprise??
  • Wed, May 16 2018 1:47 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,851
    • Points 20,445
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hi Emil.Oberg,
       Please complete your user profile, include full specs of machine. Is the drive USB 2.0 or 3.0, do you have full access/permission to the drive?
    RalphC
  • Wed, May 16 2018 2:24 PM In reply to
    No error message whatsoever. It just freezes and then crashes. I have windows 10 home 64 bit. I updated my profile.
  • Wed, May 16 2018 2:25 PM In reply to
    Hi!
    I updated my profile with the specs. The external hd is connected to a USB 3.0 port. How do I check if I have full permission to the drive? Thanks
    Specs: Windows 10 Home 64-bit.
    16gb RAM
  • Wed, May 16 2018 2:36 PM In reply to
    • Posts 10,384
    • Points 220,480
    Emil
    You are aware that Windows Home is not approved right?   MC First requires......
    • Windows 10 Professional and Enterprise
    • Windows 8.1 Professional and Enterprise
    • Windows 7 Professional (Service Pack 1 only)
    Complete specificatins are listed here:  http://resources.avid.com/supportfiles/attach/Windows_Current_CPU_Specifications.pdf As for the drive.....   how is it connected?  USB port direct or via a  USB3 PCMCIA controller?  If so which one? Marianna
  • Wed, May 16 2018 3:09 PM In reply to
    No I was not aware of that. It seems to work fine though when the external is not connected and I tried it on my friends computer wich has Windows 10 professional and it was the same problem. I have my external connected directly to the USB port.
  • Wed, May 16 2018 3:14 PM In reply to
    • Posts 10,384
    • Points 220,480
    hmmmmm..........
    Most that i know use a cheap PCMCIA USB3 card and attach to that.....    I cant try it for you as I dont have a USB3 here...
    Anyone out there that can?
    marianna
  • Wed, May 16 2018 8:43 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,581
    • Points 45,970
    What hard drive are you using. Sometimes the drive itself may be the problem. I have a 2-drive RAID USB3 enclosure connected to my editing system. I can't boot the drive with the enclosure turned on. It works fine if I boot with the enclosure off and then turn it on after the system has started. Still working on that one (might need drivers installed into the firmware).
    If you have another external drive, try that and see what happens. If that fails, then it's a problem with the USB port/hardware/driver. If not, then it's probably a problem with the drive. You should also try it with no other USB connected devices that don't absolutely have to be there (e.g. keyboard and/or mouse).
    Dave S.
  • Thu, May 17 2018 10:58 AM In reply to
    I’m using a seagate backup plus 2tb. It’s a cheap external. I tried a friends external and his worked fine so it seems to be something with my external. I’ve used it without any troubles in all other software I use for years though.
    If I get a new external to use with MC, what do I have to think about?
  • Fri, May 18 2018 6:28 PM In reply to
    • RalphC
    • Posts 1,851
    • Points 20,445
      Avid Employee
    Emil.Oberg:
      You plug both external in the same USB ports? USB 3.0 work best if you used 3.0 blue ports. Interesting to know what is the difference between the two USB drive, your friends external also have media files in it?
    RalphC
  • Tue, May 22 2018 9:04 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,590
    • Points 65,570
    Make sure that the drive is properly configured in the device manager, set it for high performance rather than quick removal. Sometimes a motherboard BIOS and the drive's firmware (if any available) update will fix these kind of issues.
    peace luca
