Latest post Mon, Jul 2 2018 11:21 PM by touviere7. 35 replies.
Page 1 of 3 (36 items) 1 2 3 Next >
  • Thu, May 10 2018 7:46 PM
    Media Composer 2018.5 NOW AVAILABLE 10 May 2018
    Avid is pleased to announce the May release of Media Composer 2018 which is available as of today, May 10th, 2018 at 3:00 PM ET.
    Location: This release is available from Avid Master Accounts, Application Manager, and the Avid Download Center (login and password required).
    Installer:  There is a Media Composer Win Full Installer.
    What’s New in this Release:  The following have been added to this release.
    • Get Info Window Update:  You can edit allowable fields in the Get Info Window.
    • Hybrid Log Gamma Color Transformation:   The white point of media is now recommended to be mapped at 75% on the HLG scale.
    • Change track in create/edit Marker dialog: You can change the track in the create and edit Marker window.
    Fixes and Known Limitations: For a full list of fixes and known limitations, see the ReadMe documentation on the Media Composer 2018 Documentation page.
    Notes:
    1. Avid DX Driver:  The Avid DX Driver is not automatically installed when you install the editing application. If you need to install the Avid DX Driver to work with your Avid I/O device, you can install it separately. The installer is located:
      • (Windows) Program Files\Avid\Utilities\DXDrivers
                There is a Win7 driver and a Win10 driver in the Utilities folder. The Win7 driver works for both Windows 7 and Windows 8 systems.
    1. Interplay and Media Composer:  Media Composer v8.7 and higher requires Avid Interplay client v3.7 and higher.
    ReadMe and What’s New Guide: The ReadMe and “What’s New” Guide for the May release of Media Composer will be uploaded to the knowledge Base Media Composer 2018 Documentation page at launch.
    How to obtain the May Media Composer 2018.5 Update:
    1.  Customers who have already installed the latest version of Media Composer will be notified of the availability of the upgrade via the Application Manager. The Apps tab also provides a link to download and install the update when desired.
    2.  New customers who purchase Media Composer will receive the update in their Avid Master Account.
    3.  Customers on current Update plans can download the Media Composer update either from their Avid Master Account or the Avid Download Center (login and password required.)
    4.  Customers NOT on a current Upgrade & Support contract must purchase either a new Media Composer Subscription or Perpetual license to receive this update.
    Reminder: This release of Media Composer requires an active Upgrade plan
    Media Composer 2018.9 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Thu, May 10 2018 7:55 PM In reply to
    • Roy-CBP
    • Joined on Tue, Feb 1 2011
    • Long Island, NY
    • Posts 6
    • Points 80
    Re: Media Composer 2018.5 NOW AVAILABLE 10 May 2018
    I just downloaded and installed 2018.5 along with the new AvidDX driver found in the utilities folder and I seem to be getting a very strange color bug.
     https://imgur.com/a/wfMwiv6 Here is the image showing color issue...
    Obviously the hand should not be blue. Any idea where this coming from?
    I am also going to a 4k client monitor through the DeckLink Mini Monitor 4k and the color on there is perfect. Exported files also come out with normal colors.
    MC 2018.4 Ultimate, Nvidia GTX1080 FTW, 64gig RAM, Intel 7th Gen i7 7700K, Windows 10 x64 Pro, BM DeckLink Mini Monitor 4K [view my complete system specs]
  • Thu, May 10 2018 8:26 PM In reply to
    • Posts 9,775
    • Points 212,535
    Roy....
    There is a new feature in 2018.5
    Hybrid Log Gamma Color Transformation Update - When doing an automatic conversion for color management, black and white points of the media are internally mapped to value 0 and 1.0 with all other levels falling in between. This is to make color space and transfer characteristics (the gamma) conversions easier.  In previous versions of Media Composer, when converting to Hybrid Log Gamma (HLG), the white point of source media was mapped to 50% on the HLG scale. This was in accordance to ARIB-B67 specifications. With the development of BT.2100 specifications, the white point is now recommendedto be mapped at 75% on the HLG scale. The is also to be compatible with non-HDR broadcasting (Rec.709.)
    With this release, by default when converting media to HLG, the mapping with be done in accordance to BT.2100. In the color transformations below, the Hybrid Log Gamma will use the 50% mapping. The Hybrid Log Gamma BT.2100 option uses the 75% mapping.
    whats you level scalling set too?  Where id this clip originate?
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, May 10 2018 8:36 PM In reply to
    • Roy-CBP
    • Long Island, NY
    • Posts 6
    • Points 80
    Okay, that all went way over my head. Here’s the bottom line, we had 2018.1 and everything looked great with this same footage, I’m not sure what my level scalling is, and this clip along with the rest of the projects clips were shot on a Nikon d850. UHD 29.97 and transcoded to DNxHR HQX. What would be my workflow for correcting this as I can not edit to negative color video clips?
  • Thu, May 10 2018 9:29 PM In reply to
    What OS and graphics card are you using?
  • Thu, May 10 2018 11:51 PM In reply to
    • Roy-CBP
    • Long Island, NY
    • Posts 6
    • Points 80
    Windows 7 Pro x64, nvidia gtx 1080
  • Fri, May 11 2018 12:37 AM In reply to
    Thanks.
    FWIW I have the same issue with MC 2018.5 with W10 Pro 64 and NVIDIA GeForce GTX 1070 but not with W7 Pro 64 and NVIDIA quadro 2000. Updating the 1070's driver made no difference.  Reverting the W10 to MC 2018.4 gets rid of the issue.
  • Fri, May 11 2018 12:46 AM In reply to
    • Roy-CBP
    • Long Island, NY
    • Posts 6
    • Points 80
    That’s great to know, how can I go back to 2018.4?
  • Fri, May 11 2018 12:53 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 581
    • Points 6,545
    hlg footage from gh5,  looks great in 2018.4 with a simple custom lut from driftwood
    now in 2018.5...
    nothing i tried to change will give the proper color back...
    wazup?
    mc 2018.9 with symphony - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2... [view my complete system specs]
  • Fri, May 11 2018 1:04 AM In reply to
    touviere7:
    I believe it is the same issue as above. The GTX 1070 and 1080 is common to each of us.  Output to client monitor via BM intensity Pro 4k here shows the correct colours.
  • Fri, May 11 2018 1:07 AM In reply to
    Roy-CBP:
    Download the 2018.4 installer.  Uninstall 2018.5. Install 2018.4.  This process will not affect any projects or media.
  • Fri, May 11 2018 1:29 AM In reply to
    • Roy-CBP
    • Long Island, NY
    • Posts 6
    • Points 80
    Thanks!
  • Fri, May 11 2018 1:07 PM In reply to
    • Dave
    • Joined on Tue, Aug 14 2012
    • United Kingdom
    • Posts 21
    • Points 235
    I can confirm this with the 1080ti on windows 10, wrong (blue) colour in the composer window but fine on the blackmagic output.
    Hopefully exporting will result in the correct colours too.
    Media Composer 2018.5, Windows 10 Pro (1709), Dell T7910, Intel Xeon E5-2687W v4 @3.00GHz 12-Core, 96GB RAM, EVGA Nvidia GTX 1080 ti SC2, Dell P2415Q,... [view my complete system specs]
  • Fri, May 11 2018 2:34 PM In reply to
    • Posts 9,775
    • Points 212,535
    Folks
    Got a case going here... # 03469889.  Al of you on this thread have been added to it so you can respond and follow along.  Looks like Andrew was right, we have ourselves a bug.
  • Fri, May 11 2018 3:02 PM In reply to
    • gswilson
    • Joined on Thu, Feb 4 2010
    • Belfast, Ireland - now, Frankfurt am Main, Germany
    • Posts 302
    • Points 3,935
    Marianna:
    Folks
    Many thanks for the "Heads Up" on this. Think I'll just stay on 2018.4 for a while longer.
    Gerry
    MC 2018.9, Win 10 Pro CE, Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 1080Ti GPU(Driver 399.07),Samsung 850 Pro 512 GB SSD... [view my complete system specs]
