Latest post Mon, May 7 2018 4:05 AM by Martin Fox. 7 replies.
  • Fri, Apr 27 2018 5:34 PM
    • mkj
    • Sweden
    • Posts 395
    • Points 5,215
    Fastest way to export a sequence from Avid to a OP1a MXF?
    have a project where export time will be critical.
    How do I get Avid export fast as possible?
    I will also need to export .mp4 h264 files.
    What kind of computer should I use? Any 3rd party apps that can do it faster?
  • Fri, Apr 27 2018 8:00 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 349
    • Points 4,095
    Re: Fastest way to export a sequence from Avid to a OP1a MXF?
    AMA file export to MXF op1a is quite fast. I have benchmarked it at 30% of realtime on a HP z840 in MC2018.4 when exporting a DNX145 sequence to DNX145 OP1a MXF. A 90 minute timeline takes about 30-35 minutes to export.
    IMO, use the MXF op1a master file to generate your H.264 MP4s in ffmpeg or similar.
    Dave
    "A very big network"
  • Sat, Apr 28 2018 10:50 AM In reply to
    • mkj
    • Sweden
    • Posts 395
    • Points 5,215
    hmm, our delivery specification says "MXF OP1a XDCAMHD"
    -you cant choose XDCAMHD" when exporting to "AMA File export", only when you choose "Export to a file"
    The media on the sequence will be XDCAM HD 50. We need to have the fastest export, should the broadcaster be able to handle a DNxHD36 MXF OP1a?
    EDIT: I want a fast export, AND a small file as possible. We will maybe have a slow upload Internet connection on this production, and it is short time between edit and broadcast...
    But after reading this excellent thread https://community.avid.com/forums/t/125792.aspx  I understand that DNxHD36 isnt good enough...
    So....export to AMA is really fast, but will make a big file(DNxHD120)
    Export to XDCAM HD 50 will take a long time and give a good quality, but will make a small file.
    But I assume that if I have a "super"-computer, export to XDCAM can get faster? What do Avid MC use most when exporting, CPU, GPU?
  • Sun, Apr 29 2018 8:12 AM In reply to
    DNxHD36 is fine depending on the target.
    AMA File Export can export as XD.
    I have examples here:
    http://community.avid.com/forums/t/184052.aspx
    Desktop PC
    3 Heads Digital Films
  • Sun, Apr 29 2018 9:30 AM In reply to
    • mkj
    • Sweden
    • Posts 395
    • Points 5,215
    hmm, how?
    Can only choose XDCAM when I choose "Export to a file"
    (running MC 2018,4)
    This is the options when choosiing AMA File Export:
  • Mon, Apr 30 2018 3:16 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 222
    • Points 2,350
    Hi I have been using this method too, but I have a problem in ffmpeg with the audio , which is presented as one channel only, of a stereo  (dual monoJ file.
    Is it possible to work around this in ffmpeg, or get a stereo (not dual mono file) from avid?
    My current work around is to separately export a stereo wav from avid and bring that into ffmpeg as an external audio file, but this is clumsy and I have experienced some timing drift on long projects.
    Any thoughts?
    M
  • Wed, May 2 2018 1:18 PM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 179
    • Points 1,940
    In ffmpeg i would think that adding this filter would make the dual mono tracks into one stereo track:
    -filter_complex "[0:1][0:2] amerge=inputs=2, pan=stereo|c0=c0|c1=c1"
    or maybe just:
    -filter_complex "[0:1] [0:2] amerge"
    You can also have a look at https://trac.ffmpeg.org/wiki/AudioChannelManipulation#a2monostereo
    Media Composer 2018.12.1 - Windows 10 - Dell 8520 - Blackmagic Decklink Studio 4K - Interplay and NEXIS storage - Avid Artist Color. Plus a lot of HP Z420... [view my complete system specs]
    Kåre Nejmann
    Danish Broadcasting Corporation - DR
    Aarhus, Denmark
  • Mon, May 7 2018 4:05 AM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 222
    • Points 2,350
    Thanks Kare, much appreciated
