Latest post Sun, Dec 23 2018 12:51 PM by William Visser. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Apr 26 2018 8:41 AM
    • William Visser
    • Joined on Fri, Apr 20 2018
    • The Netherlands
    • Posts 4
    • Points 40
    Can't play popup window from timeline record mode
    Hey,
    For quickly switching between multiple sequences, I use multiple pop-up windows. The problem is, when I toggle source/record mode in the timeline, I cant play them!
    Is there an setting for this of which I dont know?
    I tested it on a windows and a mac with the latest avid media composer version and version 8.8, but it doesn't work in any of them!
    Primary: - Intel i7 8700 4.8ghz 6 cores/12 threads - 32gb ddr4 2400mhz Corsair Vengance Ram - 256GB Samsung Evo SSD, 2x 4TB Seagate Barracuda (Intel) RAID0... [view my complete system specs]
  • Sat, Apr 28 2018 9:12 AM In reply to
    Re: Can't play popup window from timeline record mode
    William Visser:
    Is this something that worked in previous versions and now doesn't, or is it something that you'd like to have but aren't sure if it's possible?
  • Sat, Apr 28 2018 11:45 AM In reply to
    • William Visser
    • The Netherlands
    • Posts 4
    • Points 40
    Well, I don't remember it working, but if I can scrub through a timeline of the sequence/footage loaded into that pop-up monitor, it just seems logical that you should be able to play from the timeline as well right?
  • Sun, Apr 29 2018 9:40 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 914
    • Points 11,705
    I have tested this on a Windows 10 workstation with latest MC-Version, and it worked as expected. I changed the bin settings to open clips/sequences in a seperate pop-up window, after having loaded one sequence into the record monitor. I can now play either the sequence loaded in the record window or any of the pop-up windows loaded with seperate aequences. My timeline shows only the sequennce loaded into the record monitor.
    After a sequence was loaded into the pop-up window, I can draw/drag it to the record monitor as well. I can then select the timeline I wish to see, and play any sequence from either pop-up window or record window.
    Joachim
    Joachim Claus
  • Wed, Aug 8 2018 1:09 PM In reply to
    • Sion Roberts
    • Joined on Mon, Dec 5 2011
    • Manchester
    • Posts 28
    • Points 370
    Im finding the same issue as the OP - I think this did work ok for me at some point in the distant past but hasn't in the last few releases as far as I can remember.
    If I load a clip (or sequence) into a pop-up and I navigate around it in the source timeline tool, Im unable to play, mark in/out or splice into the record side.
    You can however perform these actions by scrubbing the play bar within the pop-up window itself, but this is obviously a bit cumbersome in an editing situation.
    Its consistent across the two machines I have access to but It would be good to verify this with other users... I think it's a bug worth reporting!
    Cheers
    HP Z820 Intel Zeon CPU E5-2640 @ 2.50GHz, 32 GB RAM, Nvidia Quadro M4000. Windows 10 Pro, Avid Media Composer... [view my complete system specs]
  • Wed, Aug 8 2018 7:55 PM In reply to
    • Posts 10,079
    • Points 216,475
    William
    Can you PM me your email address associated with your MyAvid and your system ID so I can get a case going?
  • Wed, Aug 8 2018 8:12 PM In reply to
    • William Visser
    • The Netherlands
    • Posts 4
    • Points 40
    Done!
  • Mon, Dec 10 2018 9:04 PM In reply to
    • bannerman
    • Canada
    • Posts 63
    • Points 780
    Marianna do you know if there is any news on this. Am i missing something? I was recently between projects and updated from 8.6.5 to the current version. But I heavily use the feature of viewing and editing from the source timeline as it allows me to better see which audio tracks I want to bring into my sequence. It was working up to 8.6.5 for me. Now it does not, making it impractical to edit viewing source timeline. Can't set IN/OUT. Can't even play it.
    Current MC. i7-4930K CPU @ 3.40GHz, 6 Cores/12 Threads. 32GB DDR4. Windows 7 Pro. GeForce GTX 760 4GB GDDR5. [view my complete system specs]
  • Tue, Dec 11 2018 2:46 PM In reply to
    • Posts 10,079
    • Points 216,475
    Steve
    Can you direct message me your system iD and MyAvid email
  • Sun, Dec 23 2018 12:51 PM In reply to
    • William Visser
    • The Netherlands
    • Posts 4
    • Points 40
    Quick update:
    I have submitted a bugreport in the AvidBeta Centercode:
    "BUG-1411"
    I also attached a video of the bug with it:
    https://cdn-b-east.streamable.com/video/mp4/fl2g6.mp4?token=4WtU7o-R13a_o235CK3uSg&expires=1545575848
    I was pretty busy lately, so I'm sorry for reporting it, this late...
    Anyways, I hope this issue gets resolved!
