Latest post Sat, Apr 25 2020 1:04 AM by Martin V. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Apr 15 2018 10:26 PM
    • Martin V
    • Joined on Mon, Oct 27 2008
    • Posts 35
    • Points 495
    Apple ProRes codecs missing
    I am editing an HD project and I just realized that I don't have Apple ProRes codec.
    I am editing in the latest Avid (2018.4) on a Mac with OS Sierra (10.12.6)
    I have attached the list of available codecs I have. At work that list is double and we don't have any special package installed.
    I tried uninstalling and re-intalling Avid but same thing happened.
    I even went to the Apple store to ask if they knew how could I get those codects. They barely knew what Apple Pro Res wasSurprise
    Any ideas?
    iMac 27"-MacOS 10.12.6 - 3.4 Ghz Intel Core i7 - 8GB GB 1600 Mhz DDR3-Avid MC 2018.4 + 27" Cinema display [view my complete system specs]
    Filed under: , , ,
  • Mon, Apr 16 2018 4:41 AM In reply to
    • mrtymcln
    • Joined on Tue, Aug 16 2016
    • Sydney, NSW
    • Posts 71
    • Points 780
    Re: Apple ProRes codecs missing
    Hello other Martin!
    You need an Apple Pro app installed on your machine to acess Pro Video Formats.
    I'd recomend purchasing Compressor as it is a fast encoder and fairly cheap; otherwise you can follow these instructions as a workaround to install the Pro Formats without purchasing/installing a Pro App.
    Media Composer 2019.6 with PF and SS | 2015 MacBook Pro with macOS 10.14.6 [view my complete system specs]
    Filed under: , , ,
  • Mon, Apr 16 2018 10:42 PM In reply to
    • Martin V
    • Posts 35
    • Points 495
    Thank you Marty, for a moment I thought you were Marty McFly!! Ha ha.
    Thank you for the info. That makes sense. I have tried so many things and your solution is one of the last things to do. i am downloading Compressor right now.
    All the best,
    Martin
  • Thu, Apr 19 2018 6:11 AM In reply to
    • mrtymcln
    • Sydney, NSW
    • Posts 71
    • Points 780
    Martin V:
    Maybe I am! Haha. Wink
    Martin V:
    Hope you're sorted now, give us a shout if you're not.
  • Sat, Apr 4 2020 11:16 PM In reply to
    • GreekGuy
    • Posts 14
    • Points 250
    Your link no longer exists, but maybe you can help.  I am missing Apple Pro Res 422 codec when doing a mixdown.  I have installed the bundle and it never shows up.  Any idea where to get the 422 codec?
  • Sun, Apr 5 2020 10:28 AM In reply to
    Are you on a Mac? Which version of MC? Project type? Which codecs ARE showing up?
  • Sat, Apr 25 2020 1:04 AM In reply to
    • Martin V
    • Posts 35
    • Points 495
    Hi GreekGuy, which bundle did you install? All you need is to install Compressor. That does the trick. In fact I bought Compressor only (it was something around 50 dollars. All considering was a good deal.
    Today, in an Avid Webinar they mentioned that 2020.4 (will release on Monday Apr 27) it is included for PC. I want to believe that for Mac too.
    If you can download that version on Monday I would wait and see if it comes with the codecs. Otherwise make sure you install Compressor.
    I hope it helps.
