Latest post Mon, Mar 12 2018 11:49 PM by ripvanmarlowe. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Mar 9 2018 6:10 PM
    • Dragonh
    • Joined on Wed, May 26 2010
    • Posts 13
    • Points 180
    Would a computer with this be good ?
    We are thinking of putting together a new machine to do editing using Media Composer. The machine would be used to edit UHD and 4K material...
    Would this be okay (All links are here to give you access to more information):
    Motherboard : HP Z800 Workstation Motherboard (http://www.compeve.com/index.php?main_page=product_info&products_id=981)
    Video card : NVidia K5200 (https://www.ebay.com/itm/Dell-Nvidia-Quadro-K5200-8GB-256-bit-PCIe-x16-Computer-Video-Graphics-Card-R93G/292449799000?epid=1737895855&hash=item44175dcb58:g:aJEAAOSw9mlahIzv)
    Processors (2 of them) : Intel Xeon X5570 Nehalem 2.93 Ghz (https://www.newegg.ca/Product/Product.aspx?Item=9SIAA404M68104&cm_re=xeon_processor-_-9SIAA404M68104-_-Product)
    Memory : Kingston Fury 16GB DDR 4 DIMM (4 for 64 GB Minimum) (https://www.bestbuy.ca/en-CA/Search/SearchResults.aspx?type=product&page=1&sortBy=relevance&sortDir=desc&query=dimm+memory+16gb)
    Internal Hard Drive (For Sotware) : Seagate FireCude 2TB 3.5" SATA III (https://www.bestbuy.ca/en-ca/product/seagate-firecuda-2tb-3-5-sata-iii-desktop-internal-hybrid-drive-st2000dx002/10604153.aspx)
    Further to suggestion, OS Drive would be a SSD: Silicon Power S55 960GB SATA III SSD (https://www.bestbuy.ca/en-ca/product/silicon-power-s55-960gb-sata-iii-internal-solid-state-drive-sp960gbss3s55s25ca/10671228.aspx)
    We will then be adding external RAID drives for all video storage (If you have any suggestions for this, I would appreciate it)
    *** Edited to correct link to Hard Drives
    HP Pavilion Windows Vista 4 Gigs RAM Using External HD different for every project AVID Media Composer v3.5 No BOB or Mojo installed [view my complete system specs]
  • Fri, Mar 9 2018 7:47 PM In reply to
    Re: Would a computer with this be good ?
    You posted the memory twice.
    However don't let the whole speed drop down from choosing anything else than an SSD for OS.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Fri, Mar 9 2018 8:40 PM In reply to
    If you want a quick machine I'f go at least HP Z820 or 840 the 800 is getting on now.
    Re the RAID don't be tempted with RAID 5 go RAID 10 if you need protection or RAID 0 if you just want speed.
  • Mon, Mar 12 2018 4:09 PM In reply to
    Wouldn't bother with the Z800.  That is a seriously old piece of kit now.  Also limited to PCI-e 2.0 so any new graphics card/interface card you put in there that uses PCI-e 3.0 will not benefit from extra bandwidth.  Z820 is the first of the Z line to support PCI-e 3.0 as far as I'm aware.
    Also, the memory you have chosen is completely incompatible with that Motherboard.  Honestly I wouldn't be trying to build some sort of home-brew workstation with a Z800 as the base.  You need to do much more research in to what components work together.
    Seagate drives are also known for high rates of failure:
    https://www.backblaze.com/blog/hard-drive-stats-for-2017/
    As others have mentioned, it's SSD or bust for the boot drive.  Time for a re-think methinks!
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Mon, Mar 12 2018 8:44 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,235
    Look at Supermicro workstation boards as a starting point, either dual or single processor.
    Media Composer v8.9.2 | Windows 10 Professional 64-Bit | Supermicro X10DAi | Intel Xeon E5-2620 v4 Broadwell (x2) | Noctua NH-D9DX i4 (x2) | PNY GeForce... [view my complete system specs]
  • Mon, Mar 12 2018 11:49 PM In reply to
    I can see you've added an SSD in there.
    1) It's a SATA based SSD - you will get much better speed with a PCI based SSD.
    2) The Z800 only supports SATA II - up to 3 Gbps, so you won't even be getting the full speed of the SATA III drive you have linked to.
    Honestly, the list you've put together is both underpowered and more importantly, the components aren't compatible with each other and you won't get the thing to work.  You'd be much better off just buying a used Z820/Z840 from ebay that already has the memory, HDD, OS, etc installed. Then if you really want you can pimp it out a bit higher powered components, but at least you're starting from a solid base.
    If you haven't built a PC from scratch before - which it seems may be the case, then doing so for a workstation that you want to run your business from is not a good idea, not to mention the fact that if it won't be a supported spec as recommended by Avid.
    Take a look at the Avid supported configurations list and see what hardware you need in order to be safe.
    The total price of all the components you have listed will easily buy you a solid HP Z workstation that is Avid certified and will just work straight out of the box.  Please don't go ahead with above build, it will definitely cause you problems.
    Hope I'm not coming across as pushy or anything but I'd hate to see you waste your money on an old machine with outdated hardware, especially as you say you want to cut UHD/4K material on it which will require a good whack of power.  You can pick up fully built Z800's on ebay for next to nothing nowadays so if you really want to go that route then just buy one fully built.
    My 2 cents
    Andi
