Latest post Sun, Jan 21 2018 12:10 PM by Roger Shufflebottom. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Jan 4 2018 5:59 PM
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 222
    • Points 2,980
    MC 8.10 matte key crop - level changes
    Noticed one thing - that all imported graphics on my timeline renders differently from previous versions.
    Found that if i only place mate keyed video on the timeline - it renders correctly
    But if i change crop in matte key - it became grayed and washed in levels - i can see crop border where it was transparent.
    It happens only in 8.10. So i can not render all my previous projects correctly.
    MBPro_late_2013 15'' i7 16GBram OSX 10.12.4 MC 8.9.0 AJA io XT , EXT thunderbolt NvidiaGPU 980ti; Baselight plug-in; MacPro2010 SSD, 2x4core, 32GBram... [view my complete system specs]
    DJFio[DB]
  • Fri, Jan 5 2018 11:30 AM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 479
    • Points 5,735
    Re: MC 8.10 matte key crop - level changes
    I'm noticing the same thing.
    This also happens when using Title tool. The work around here is to change the effect to 3D and the fuzziness seems to go away.
    Media Composer 8.10.0 New MacPro 6 core - 32 GB RAM old MacPros 3.33Ghz iMacs, Macbook Pros. BM, AJA, Matrox After Effects, etc [view my complete system specs]
    @jaketheeditor
  • Tue, Jan 9 2018 3:53 PM In reply to
    • derDoyle
    • Joined on Tue, Aug 18 2015
    • Posts 47
    • Points 510
    Had a similar issue with graphics in a previous version. Turned out to be the enabled GPU-render-Option in the render-settings. After turning off all my graphics rendered correct.
    Clients: MacPro6.1 (2013 "Trashcan"), 3,5GHz 6-Core, 16GB (1866) RAM, AMD FirePro D500, 256GB SSD, macOS 10.12.2, Avid MediaComposer 8.7.2, NitrisDX... [view my complete system specs]
  • Wed, Jan 10 2018 8:16 PM In reply to
    • dharia
    • Joined on Fri, Sep 19 2008
    • Posts 173
    • Points 2,165
    Hello
    I am noticing this issue too. If I have a Tiff file I have imported with an Alpha that is placed over a video, if I crop the clip with alpha, the text I had in it gets all jagged, and the levels change as well to make everything washed out. If I change teh Matte Key'd clip to a 3D effect it doesnt' fix it, nor does turning off the GPU effects in render settings.
    Can a fix be provided for this asap, because it is an issue that could affect all AVID editors.
    2010 8 Core Mac Pro, Nitris DX, Media Compoer 8.6, 22GB Ram, 7200RPM Western Digital Black Hard Drive, Radeon R9 280x 3GB graphics. [view my complete system specs]
  • Thu, Jan 11 2018 1:03 PM In reply to
    • derDoyle
    • Posts 47
    • Points 510
    Ok, I checked this issue on my 8.10 and it is much worse than I thought and it has nothing to do with my issue in which disabling GPU-render worked.
  • Thu, Jan 11 2018 1:08 PM In reply to
    Oh Oh. Testing.
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
  • Fri, Jan 19 2018 9:55 PM In reply to
    • dharia
    • Posts 173
    • Points 2,165
    Has anyone found a fix for this? It is also still there in MC 2018.1  . I think it should be prioritized.
  • Sun, Jan 21 2018 10:19 AM In reply to
    I see it here. 8.10 on Mac:
    iMac i5 27", 24GB RAM, OS 10.11.6 with Symphony 8.8.5, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.12.5 (oops) with MC 8.8.4. Very old... [view my complete system specs]
  • Sun, Jan 21 2018 10:27 AM In reply to
    • jakeheat
    • Posts 479
    • Points 5,735
    Have you tried promoting to a 3D effect? That may be a workaround for now.
    @jaketheeditor
  • Sun, Jan 21 2018 12:10 PM In reply to
    Yes, that does work - thanks.
