Latest post Fri, Oct 18 2019 9:52 AM by kd-53. 10 replies.
Page 1 of 1 (11 items)
  • Tue, Jan 2 2018 11:17 AM
    • kd-53
    • Joined on Wed, Apr 28 2010
    • Duesseldorf, Germany
    • Posts 32
    • Points 415
    MC doesn't show USB Soundcard + Micro
    the audio punch-in tool does not show my new USB-Soundcard (Rode NT1 + AI-1). As a BOB I use the Matrox MX02, which still works fine. But when I want to enter the voice over via punch-in tool, I can only choose between Matrox and Host-1394. Both do not make sense. No Windows-Mixer or Micro is availiable. If I switch off the power of the Matrox MX02 AND THEN reboot the computer I can choose between Windows-Mixer with the Micro and Host-1394 (I do not have any Host-1394 device). Of cource the Matrox does not work any longer. If I want to take use of the BOB I have to do it the other way round: switch on the power of the BOB AND THEN reboot. Of course than I do not have access to th micro.
    Why is it not possible to have the BOB and the micro? What am I doing wrong. My current workflow with switching the power supply on and off and reboot does not make any sense.
    Best regards
    kd-53
    Mobo: MSI MPG-Z390 Gaming Edge AC, i9-9900K, 32GB Ram, Win 10 Prof 64, GeForce GTX 2060 Super with 8 GB Ram, BM Intensity Pro 4K, MC 2019.12.1, BCC11,... [view my complete system specs]
  • Tue, Jan 2 2018 10:11 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,159
    • Points 24,025
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: MC doen't show USB Soundcard + Micro
    Hello kd-53,
       I opened a case for support to assist you with the issue.
    03367723.
    RalphC
  • Tue, Jan 2 2018 11:07 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    That's normal behaviour: the Windows mixer is not available with an I/O box connected. No need to turn the device off and reboot though, You can disable the MX02 with the timeline button and the USB mic will be available. Why can't we choose whichever audio device we want when a BOB is connected is a misterious mistery, may the reason be that You have to buy an Avid I/O with a built in mic input? ;-)
    Symphony 20.06, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Thu, Jan 4 2018 6:52 PM In reply to
    • kd-53
    • Posts 32
    • Points 415
    Hi RalphC,
    thank you for your assistance.
    The customercare sent me the following mails:
    Hi KD,
    Good day! This is regarding your case on Media Composer. My concern in here is that Matrox is no longer supported on recent versions of Media Composer. The last version it was working fine is on Media Composer 8.4.5 and since then, they haven't release any new drivers. With this, it might be a conflict with your set-up.
    Kind regards
    Hello Klaus-Dieter,
    The behavior is as designed. It is not currently possible to sync 2 devices that have different audio drivers. You can either use an I/O or external soundcard, but not both at the same time.
    The Host-1394 is the firewire port on the machine. It's seen by default and it can used if you have a deck connected to it.
    Kind Regards
    Hello Klaus-Dieter,
    The same result will be seen on the BMD Intensity Pro 4K as well. You need to disable it, in order to get audio through the external USB audio card, because the Media Composer can only use one audio driver at a time.
    You can of course also disable this from the timeline shortcut, and you don't need to physically remove the device from the machine. (screenshot attached)
    Kind Regards
    So they helped me and the case has been closed.
    Hello luca.mg,
    also a thank you to you. I did not know that there is a button in the timeline to switch off the BOB (shame on me, I still have to learn a lot).
    Best regards
    kd-53
  • Sat, Jan 6 2018 9:30 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    Hi Klaus and sorry for the delay, I'm not getting forum notifications. Glad to hear that You're in control. No need to thank. Unfortunately the MX02 is EOL, it used to get along very well with MC; it's a Matrox decision. Happy editing and happy new year, Luca
    peace luca
  • Wed, Oct 16 2019 2:41 PM In reply to
    • kd-53
    • Posts 32
    • Points 415
    Hi everyone,
    I recently switched from MC 2018.12.5 to MC 2019.9 and now I have the same problem again: MC does not show the audio mixer (I hate this!). Of course I switched off client monitor (what is the reason that I have do this, but that is another question). Under settings --> Audio project I only see "Host-1394" and "Black magic". What can I do to force MC to use the windows audio-mixer.
    Please help
    Best regards
    kd-53
  • Wed, Oct 16 2019 9:23 PM In reply to
    • RalphC
    • Posts 2,159
    • Points 24,025
      Avid Employee
    Re: MC doesn't show USB Soundcard + Micro
    Did you create a new user profile after the upgrade to MC2019.9? A new user profile is a must.
    RalphC
  • Thu, Oct 17 2019 7:40 AM In reply to
    • kd-53
    • Posts 32
    • Points 415
    Yes, I did.
    kd-53
  • Thu, Oct 17 2019 8:33 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,689
    • Points 66,755
    kd-53:
    Hi everyone,
    Please help
    Best regards
    kd-53
    What is the default Windows sound card? If it is the BM it'll be the available choice when Yoy disable the I/O hardware, You may want to cange the default Windows sound card.
    peace luca
  • Thu, Oct 17 2019 9:04 AM In reply to
    • kd-53
    • Posts 32
    • Points 415
    In windows standard output is: loudspeaker (Realtek High Definition Audio)
    Input: USB Mikro (RHODE AI-1)
    I the windows settings I even swiched off audioinput "Blackmagic Intensity Pro 4K Audio"
  • Fri, Oct 18 2019 9:52 AM In reply to
    • kd-53
    • Posts 32
    • Points 415
    No ideas?
    kd-53
